Re: Corolla 99 Error code P0441
It started one day while i was late and flooring to make some time. The check engine lite up so back home i check it out and it was code P0441.
Hey toyocrap - I have the same problem that started when I was flooring it too. I've read a lot about what the possible problems can be (bad gas cap, charcoal canister, MAF sensor, etc) but before I go to the dealer and spend $400+ I was wondering what solution you found since your problem started the same way mine did...
