Steering Wheel Vibration...
+ Reply to Thread
Results 1 to 6 of 6
Thread: Steering Wheel Vibration...
  1. #1
    Rookie Setioits is on a distinguished road.
    Join Date
    Oct 2006
    Location
    Cambridge
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Exclamation Steering Wheel Vibration...
    i have a 2001 corolla. Its been in and out of garages for the past few months trying to get rid of this steering wheel vibration problem. I'm not a car person so i'm not sure if this is normal. The steering wheel vibrates at high speeds. anyting over 50mph or so. The weird thing is it vibrates in waves. it goes from smooth to a noticable vibration over and over again. Logic would tell me if i had a damaged rim or needed a rotation the shaking would be constant, but i'm not a car guy like i said. anyone have an idea of whats going on? i'd keep on seeing mechanics but i don't feel like opening my bank account monthly to them. its been in for a damaged rim and its been in for a balancing and rotation. Unless i was charged for these services that never happened i'm not sure whats going on.
    please help.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Rookie rolla is on a distinguished road.
    Join Date
    Jul 2006
    Location
    kwinnana
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Default Re: Steering Wheel Vibration...
    hey mate it good be ur wheel bearings need adjusting if there to loose it will vibrate at high speeds and shutter when u brake. Jack up the wheels put 1 hand at the top and 1 at the bottom of the wheel then move it towards u and away from u if its loose u will feel and here a knocking sound.
    hope it helps
  4. #3
    Supporter cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy's Avatar
    Join Date
    Jun 2005
    Location
    Central Midwest (KS, MO)
    Posts
    884
    Liked
    0 times
    Rep Power
    928
    could also be an alignment issue. i believe this periodic vibration symptom is somewhat classic of alignment problem or worn suspension parts. if rotating the tires or balancing doesn solve or change the location of the vibration, that is what i would look at next.
    2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
    Wish list: too long, wife would kill me!
    2003 Corolla (bone stock, but well loved and cared for!)
    "Expect the impossible."
    - JC and the Brothers of Thunder
  5. #4
    Rookie presrco is on a distinguished road.
    Join Date
    Nov 2006
    Location
    London
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Did you check the brake rotors in the front? make sure they are not warped. Another thing you can check is your suspension. Let us know what you have done and check so far. If you have not done the alignment or wheel balancing then check those 2 things I mentioned.
  6. #5
    Veteran Member TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC would rather be driving his reputation. TACODOC's Avatar
    Join Date
    Apr 2005
    Location
    Murrieta, CA
    Posts
    1,100
    Liked
    1 times
    Rep Power
    693
    Tires balanced?
    4WD Toyota Tech and Overland Adventures: WWW.TACODOC.COM
  7. #6
    Lurking Member viper2k82 is on a distinguished road.
    Join Date
    Dec 2006
    Location
    Nashua
    Posts
    30
    Liked
    0 times
    Rep Power
    7
    One other thing that was not mentioned that is a slim possibility but it could happen is that the weight on your axel has either moved or gotten damaged so that the axel vibrates but you may notice a larger vibration. You can narrow it down to the front of the vehicle. Have you tried rotating and seeing if the vibration moves from your steering wheel to your seat? That could be a bad tire. The alignment and suspension checks are a great idea too. keep us posted! Good luck!
  1. New Tundra XSP Owner - steering wheel question
    By FLTundraXSP in forum 1Gen-Tundra
    Last Post: 08-18-2006, 01:12 PM
  2. manual steering wheel tilt adjustment issue
    By mikeinaustin in forum Suspension & Axle
    Last Post: 08-12-2006, 06:13 PM
  3. audio controls on steering wheel
    By hardliving in forum Audio & Stereo
    Last Post: 03-13-2004, 04:58 PM
  4. Replies: 5
    Last Post: 08-11-2003, 01:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
