Re: Steering Wheel Off Center
I had the same problem on my '06, and found the fix easy.
Jack the front end up, and put jack stands under the car to support it.
DO NOT under any circumstances crawl underneath the car unless you are absolutely sure the stands are stable.
I watched a friend get crushed by a car who thought the jack was enough.
That was the day I learned that stupid people die for stupid reasons.
Now if you're sure, then slide underneath, and look at the tie rod ends.
They have a large locking nut that holds the steering rods from rotating.
All you have to do is shorten one side, and lengthen the other.
In other words, screw the right side in a little bit, noting exactly how much you turn the rod, and then go to the left side, and screw it out a little.
It does not take much of a turn to move the steering wheel a lot. So easy does it.
Then before you let the car down, make sure both locking nuts are tight.
Try your setting out. If you are lucky, (I'm not.) you might only have to repeat this procedure a second time.
The reason both sides must be moved at the same time, is so that the toe-in remains the same.
If you change only one side, you will change the toe-in measurement.
BE CAREFUL! Have fun. And don't be stupid.
