Old 12-12-2006, 01:23 PM
2007 Toyota FJ Cruiser
Last Online: 03-31-2008 04:04 PM
fjtrder is on a distinguished road.
fjtrder's Photo Albums
Default 02 Corolla - Passenger Power Window Failing
hi, my wife has the 2002 Corolla S, and recently the passenger power window becomes stuck. After a while the window will eventually move up, but it seems like it could be a bad motor or electical connection.
has anyone had a problem like this?
Thanks
Old 12-13-2006, 08:46 AM
Dealer : Toyota of Huntington Beach
- Other -
Last Online: 12-13-2006 08:59 AM
tardelli is on a distinguished road.
tardelli's Photo Albums
Default Re: 02 Corolla - Passenger Power Window Failing
Thanks
I had the same problem and I discovererd that was a bad electical connection and the solution for me was disconect de electical plug and spray WD in the electical plug and assemble again
for me it works
good luck
Old 12-14-2006, 06:32 PM
which electical plug did you spray? the one in the actual door that is attached to the motor? thx
Old 06-25-2007, 11:11 AM
Dealer : Antioch Toyota Scion
2002 Toyota Corolla
Last Online: 06-26-2007 11:07 AM
hoju1398 is on a distinguished road.
hoju1398's Photo Albums
Hello,
Hello, I am new here and I own a 02 corolla. I'm actually having the same problem as the topic creator. I removed the panel and actually sprayed wd40 in both plugs (the one that connects the door panel to all the wires, and the plug that has the 2 wires going to the driver window motor) with no luck. I also checked the connection on the plugs to make sure they were not bent maybe not connecting properly.
Has anyone else run into this problem? It seems like the drivers side window runs out of power.. you almost need to let it sit around for a few mins before trying again, and at that time it only moves less than an inch. It has gotten progressively worse over the months.
I just want to say thanks in advance, there is a lot of great info on this site
Old 09-16-2007, 08:04 AM
Dealer : Toyota of Concord
Last Online: 11-20-2009 10:01 PM
hussman33 is on a distinguished road.
hussman33's Photo Albums
Hi,
I have a 98 corolla and the same is happening to the driver's front window - the one that has had the most use over 170k miles! I'll let you know what I find, but suspect loose wiring or a switch, since the motor seems strong when engaged.
Old 09-16-2007, 10:53 AM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
The drivers side Master Control of all windows is generally the culprit.
It is an actual Window ECU and as a "brain" for all windows will tend to fail.
This happens to all Toyotas with power windows.
I wood focus on the driver door Main switch if yu can conclusively eliminate a mechanical failure being the problem with your window. I.E., bad track , motor or disconnected harness. and these are easy to figure out.
The main Driver master switch does not come cheap! And the whole unit (all 4 Buttons )gets replaced as an assembly.
PS, I always try to avoid open windows especially Drivers window when it is raining. Water obviously damages this component. I've seen this problem at dealers over and over for years.
I have taken many of these switches apart. They are disposable and really cannot be repaired. And, I noticed water damage. Despite the fact that they appear to be shielded for water exposure to some degree, by design.
LT
Sliding Power Rear Window? davser Interior & Exterior 14 11-17-2009 01:29 AM
Toyota 4Runner Offers Winning Blend of Capability, Comfort, Power, Safety and Style TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:43 PM
Toyota Sienna Gets Power Infusion For 2007 TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:33 PM
Power Window Switch mitchr Interior & Exterior 5 11-14-2002 11:09 AM
Power sliding back window nhparrot Electrical & Computer Systems 0 03-28-2002 01:17 PM
