Go Back   Tundra Solutions Forum > Cars & Vans Forums > Corolla Matrix
Corolla Matrix General discussion forum for the Toyota Corolla and Toyota Matrix.
This is a discussion thread titled "Cruise Control upgrade?", within the Corolla Matrix forum, part of the Cars & Vans Forums category.
Old 01-06-2007, 05:04 PM
Dealer : Vandergriff Toyota
2006 Toyota Corolla
r2texas's Photo Albums
Last Online: 04-27-2007 05:00 PM
r2texas is on a distinguished road.
Default Cruise Control upgrade?
Anybody know what all must be installed to put in an OEM cruise control on a 2006 Corolla?
Old 01-28-2007, 07:17 PM
Dealer : Vandermeer Toyota
2006 Toyota Corolla
lakeport233's Photo Albums
Last Online: 01-29-2007 08:00 AM
lakeport233 is on a distinguished road.
Default Re: Cruise Control upgrade?
yes I have done it myself......you buy a Cruise Control switch from Auto Parts Fast at RockAuto for 33.00 and install it yourself.....the part is used on Matrix,Corolla and Pontiac Vibe ...
ACDELCO Part # D1919E {#88974274}
SWITCH,CRCONT 1ST DESIGN; USED UP TO VIN #5Z437578-2ND DES 88974274; w/COMFORT & CONVENIENCE PKG(Z05)$34.89U.S
Old 03-08-2007, 01:34 PM
hancydan's Avatar
Dealer : Bill Penney Toyota
2007 Toyota Corolla
hancydan's Photo Albums
Last Online: 06-26-2008 07:42 PM
hancydan is on a distinguished road.
I just installed one on my 2007 Corolla CE. All you have to do is cut a rectangle hole on the lower right side of your steerling wheel plastic and install the handle switch with 2 provided mounting screws. You have to take the airbag off for installation.
The later half year 2004 and later models are Drive-by-wire. That means all you have to do is install the switch and plug in the connector in the steerling wheel receptacle behind the airbag. There is no physical throttle cable to run to the engine compartment.
Depends whether it is manual or automatic. The manual has one extra wire to run to the clutch limit switch to disenge the Cruise when the clutch paddle is pressed.
If you are looking for aftermarket brand, use Rostra 250-1768; for manual, it is 250-1771.
It took me a little over one hour to install. Cuting a neat rectangular hole takes the most time. Toyata dealers cost $90x2 plus tax and shop fee just for the installation.
Old 04-25-2007, 09:03 AM
Dealer : Cobb County Toyota Scion
2007 Toyota Corolla
raji651's Photo Albums
Last Online: 04-29-2007 02:06 PM
raji651 is on a distinguished road.
Hi hancydan & lakeport233
I also have a 2007 Corolla CE. Where did you buy the cruise control switch from? I called 'www.thecruisecontrol.com' and they want $150.oo for a Rostra 250-1768. A local dealer is only charging me $210.oo including assembly and parts.
And More over is there any thing else to switch it 'on' on a CE model without a cruise control? It would surprise me that by adding only the cruise control switch ... it is going to work.I was told by ACDELCO rep that I may need some other module to curise control to work but he was not sure. Acdelco part no D1919E {#88974274 menstioned in this forum is designed for Pontiac Vibe.Pls let me know if I can use it on 07 corolla CE Automatic
Chees
Old 04-26-2007, 05:07 PM
hancydan's Avatar
2007 Toyota Corolla
Smile Re: Cruise Control upgrade?
Chees
Since you got a 2007 CE as me, the installation is the same as what I went through. I know nothing of the AC Delco part (D1919E) since I cannot get any picture from any web site. I did not want to chance it.
I bought the Rostra 250-1768. Yes, I paid $130 for it, and Yes, there is nothing else to buy. It is Drive By Wire, there is NO Module to install. Just look at my previous post for detail. The trickiest (hardest) part is to cut the rectanglular hole on the right side of the steerling wheel cover. The switch is on the Cruise Control arm itself.
Go to the dealer and take a look at the other Corolla Cruise Control. It even lit up the CRUISE light in your dash panel. PM me if you need more help.
Old 04-26-2007, 08:25 PM
mlong30's Photo Albums
Last Online: 09-18-2007 05:41 PM
mlong30 is on a distinguished road.
Can one be added to a 2000 Corolla VE?
Thanks.
Matt
Old 04-26-2007, 08:52 PM
hancydan's Avatar
2007 Toyota Corolla
Thanks.
Matt
Yes, but it is more complicated since that year model id NOT Drive By Wire; that means the computer does not directly control the throttle.
So you have to add more than just the cruise control switch. It requires Cruise Control Module, throttle cable, and more.
Old 05-05-2007, 08:36 PM
Dealer : Al Hendrickson Toyota
2006 Toyota Tacoma,
2007 Toyota Corolla
sds1100's Photo Albums
Last Online: 05-05-2007 09:24 PM
sds1100 is on a distinguished road.
I'm gonna try to get switch from a salvage yard, which toy models and years would have the same switch? I got one from a 1999 toy camry, is that the same?
Old 05-14-2008, 02:19 PM
Dealer : Sandy Springs Toyota Scion
2004 Toyota 4Runner,
2002 Toyota Tacoma 4x4 xtrcab,
2000 Toyota Corolla,
1995 Toyota Supra 94 TT
ttman's Photo Albums
Last Online: 09-29-2008 03:11 PM
ttman is on a distinguished road.
is there a link to do this? I want to upgrade my 2000 as well.
Similar Threads for: Cruise Control upgrade?
Dynamic Laser Cruise Control TS Support Toyota, Scion & Lexus News 0 09-20-2006 08:07 PM
Lexus Technology Roundup 2007 TS Support Toyota, Scion & Lexus News 0 09-12-2006 07:53 AM
Cruise Control Adjustment... ravencr 1Gen-Tundra 45 08-08-2006 07:59 PM
Cruise Control Problem mbd0722 Tacoma 2 07-31-2006 03:40 PM
Non-factory Cruise Control Problems??? file014 Electrical & Computer Systems 2 09-23-2003 08:45 PM
