How to remove manual window handle?!
  1. Welcome to Toyota Tundra Forums : Tundra Solutions Forums Ė General discussion forum for Toyota Trucks
+ Reply to Thread
Results 1 to 4 of 4
Thread: How to remove manual window handle?!
  1. #1
    Join Date
    Mar 2007
    Location
    Bloomsburg, Pa
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default How to remove manual window handle?!
    Ok newby here, but Iíve searched a couple times and I cannot find how to remove the window handle itself. All the PDF links are non existent anymore. On most cars you just pry the handle straight off however on my 98 corolla I cannot remove this. I have removed all screws and clips to the door panel itself so far, but I cannot remove this damn handle. Is there any specific trick to it or did the previous owner possibly glue it into place???
    Thanks for any possible help
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member monolithic's Avatar
    Join Date
    Aug 2002
    Location
    Central NJ
    Posts
    375
    Liked
    0 times
    Images
    17
    Rep Power
    13
    Default Re: How to remove manual window handle?!
    There is a "c-clip" of sorts that holds on all manual window cranks. I typically use a thin rag (like a t-shirt) and wedge it behind the crank and pull up and back and forth on the ends to try and pop the c-clip out from the crank handle. Since you typically can't see the two ends of the clip, you may have to work your way around the crank (360 degrees) while pulling up and back and forth on the rag.
    2004 Toyota Tundra V6 Reg Cab 2wd Auto (Phantom Gray)
    Options - Tilt wheel, Intermittent Wipers, AC, Mudflaps, Cold weather package, Bed liner (removed), Carpet floor mats, Trailer hitch receiver, Door sill protectors
    Mods - Cruise Control w/factory dash indicator, Hellwig Anti-Sway Bar, Chromatic Mirror w/Temp & Compass, Phantom Gray Door Edge Guards, PT Industries Raptor SS Nerf for Access Cab, Fog Lights w/Factory Head Lamp Switch; Great Covers velour seat cover, 2004 Reg Base Cab Cargo Light Mod (use factory switch, no light when door opened), 2004 Reg Base Cab Auto Headlight Off Disabled Mod (lights stay on when door opened); SR5 Chrome Wheel Arch Moldings; Chrome power & heated side mirrors w/factory heat switch;Burlwood control faceplate & door switch panels; Overhead console w/garage opener & Luxeon Star LEDs; Alpex #244 Chrome dual air horns - 118db - 405Hz/450Hz - 15A; Horn baffle removal mod; Rostra Radar Backup Sensors;Pilot PL-250 Backup 55w Lights; H4 Osram Silverstar Headlights; Enkei Brawn II alloys; 245/70/16 Revos; Power Outlet Mod; Ltd Visors w/lights; RainTracker rain sensor; Factory power windows; Manik tail light SS guards #925659SP; Power door locks (DEI relay module 451M); ATS grill;ARE MX camper shell (full side screens & w/o vista window); CompuStar 2W900FM(S) Remote Start/Keyless Entry/Ignition Auto Lock;Bed Carpet Kit w/Couch & Storage Boxes; Pop&Lock PL8500 Pwr Tailgate Lock; WeatherTech Mats, TRD LSD
  4. #3
    Join Date
    Mar 2007
    Location
    Bloomsburg, Pa
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Yup, I found it. Thanks for the quick reply.
  5. #4
    Junior Member tacomatrdsport2591's Avatar
    Join Date
    Jan 2005
    Location
    Elimsport, PA
    Posts
    152
    Liked
    0 times
    Rep Power
    11
    Well, not that it contributes much...but I'm bored...so the plastic C-thingie is called a snap ring!
    BOOM what a contribution that is.
    Lol...good luck with everything!
    "Close your mouth before you chew."--Marie Barone....."Close your mouth before you talk!"--Frank Barone
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Rear window latch broken
    By bluetundra in forum Interior & Exterior
    Last Post: 08-29-2008, 04:56 PM
  2. El. Window Relay Failure?
    By gagetman in forum 1Gen-Tundra
    Last Post: 06-24-2008, 10:07 AM
  3. Best oil to run in the 4.7 Tundra?
    By SMOKEATR in forum Engine, Intake, Exhaust, Induction
    Last Post: 03-22-2007, 03:33 PM
  4. COMPLETED GROUP BUY: CR Laurence Group Buy is Here!!!
    By keninsb in forum Group Buys and Vendor Specials
    Last Post: 12-12-2005, 07:52 AM
  5. Power sliding back window
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:17 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
