Re: where is the fuse box for the 2003 toyota matrixs radio
Check the GAUGE/CIG/and DOME fuses.
The DOME is under the hood in the long fuse box
The GAUGE AND CIG are on the drivers side up under the dash. You have to lay on your back and look up to see them.
25 yrs with TOYOTA
