Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "a/c fan not working", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-06-2007, 08:58 PM
Dealer : Bob Tyler Toyota Scion
2003 Toyota Tundra
jogan's Photo Gallery
Last Online: 07-12-2007 08:52 PM
jogan is on a distinguished road.
Default a/c fan not working
not sure if this goes in electrical or not but like the title says, the little fan that blows in the wonderful air conditioning finally pooped out. it figures that in the first week of july in the hot state of florida, the a/c fan quits on me. everything else seems fine. all the lights work. all the other switches seem fine. even the a/c is on and the vents on the dash get condensation on em and feel cold to the touch. i just can't get the little fan to turn on. hopefully this is a simple fuse or relay that i can replace. any help would be much appreciated. i'll call the dealer in the morning but it's the weekend so i don't know how much luck i'll have there. thanks in advance.
Old 07-06-2007, 10:17 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
UnSub's Photo Gallery
Last Online: Yesterday 10:35 PM
UnSub is on a distinguished road.
Default Re: a/c fan not working
I assume you tried the blower at all speeds and none worked. If so, the problem is not the blower resistor. If it works on high only, it is a bad blower resistor. Check the 10 amp "gauge" fuse and the 50 amp HTR fusable link. Check pin 5 of the HTR relay for 12 volts(with the relay removed). If there is 12 volts there, the fusable link is good. If the 10 amp gauge fuse is good, remove the HTR relay and jumper from pin 5 to pin 3 of the socket with the blower switch on. If the fan runs, the relay is bad.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner
Old 07-07-2007, 07:45 AM
2003 Toyota Tundra
roger that. i'll try it this morning and let ya know if it worked! thanks for the quick reply.
Old 07-07-2007, 09:10 AM
2003 Toyota Tundra
ok, the 10 amp guage fuse is fine. i assume the 50 HTR relay is fine. now when you talk about checking pin 5 and then running a jumper from pin 5 to pin 3 is where you lost me. when i remove the 50 amp HTR fuse/relay, there's only two posts available. am i removing the wrong thing? and no, the fan doesn't work on any of the settings. i don't think it's a bad fan switch because when the a/c is on and the fan is in the off position, the engine idles fine but when i turn the fan on (even though it doesn't blow) the engine idles changes to indicate a load on it for the a/c.
Old 07-08-2007, 01:12 AM
UnSub's Avatar
The HTR relay will have 4 or 5 posts that plug in to a socket. It is a seperate item than the fuse. Remove the relay and see if there is 12 volts at pin 5 of the socket, The 50 amp fuse is good if there is 12 volts at that pin. If there is 12 volts, leave the relay out and jumper pin 5 to pin 3 of the socket (with the blower switch turned on). If the relay was the problem, that will make the fan run. If the fan does not run, something else is the cause. I hope that helps. Good luck.
Rhino Liner
Old 07-08-2007, 09:32 AM
2003 Toyota Tundra
ahhh, gotcha. we'll try it again and see. thanks again.
Old 07-10-2007, 10:10 AM
UnSub's Avatar
Did you get this fixed yet? What was wrong?
Rhino Liner
Old 07-10-2007, 04:13 PM
2003 Toyota Tundra
had to surrender to the demons and take it in to the dealer. $75 later, i got a new fan motor. they must have known i was just past the warranty...... thanks for the help, though. i can now take apart my dash with record time!
Old 07-10-2007, 06:32 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Gallery
mustang67408 will become famous soon enough.
Next time just give the fan motor a good thump with your foot or hand.
If it starts working then its the motor. Its a very common problem in Toyotas.
If it doesnt work then trace down the circuit as described earlier.
HKISER gave you excellent advise
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
Old 08-10-2007, 12:50 PM
Dealer : Daytona Toyota Scion
jmcguirefl's Photo Gallery
Last Online: 04-15-2008 11:30 AM
jmcguirefl is on a distinguished road.
I am having the same problem. i have checked all the fuses and they are fine, i have the relay out and i have 12 volts at 2 points but there are no numbers to tell me which is pin 3 or pin 5. Nothing on the relay itself either, do you have a picture or the pin assignments for the 50 amp heater relay? or know where i can find them.
Thanks
Old 08-10-2007, 01:26 PM
Just thumped the motor after checking the relay and it came back on.
Thanks
Old 04-12-2008, 10:06 AM
Dealer : Bighorn Toyota
xsnowpig's Photo Gallery
Last Online: 05-16-2008 03:58 PM
xsnowpig is on a distinguished road.
where is the blower motor resistor and how do you change it?
my 2000 tundra blower motor only works on high.
Old 04-28-2008, 10:40 PM
dubesrus's Photo Gallery
Last Online: 06-30-2008 02:12 PM
dubesrus is on a distinguished road.
Default Same problem
My A/C - Heater fan only works in high speed on my 2000 Tundra. A/C compressor comes on at all speed settings, but the fan only runs on high speed.
From various posts, it must be the relay or resistor.
I've not be able to remove the heater relay. I cannot figure out how to release the retainer clips on the base of the relay.... cannot reach them. Is there a special puller? I've loosed the relay/fuse tray and can get to one side but not the other side which is against the 120 amp fuse holder.
Also, where this resistor is located?
Bookmarks
Similar Threads for: a/c fan not working
A/C fan speed VS M.P.G. rc846 1Gen-Tundra 5 04-02-2007 04:42 PM
A/C Not Working!! hobbes013 Tacoma 2 03-13-2007 06:31 AM
Why does my A/C comes on in windshield mode and how do I turn it off? boomersan 1Gen-Tundra 15 06-30-2006 08:13 AM
05 Tacoma A/C not working Walter Tacoma 5 09-16-2005 10:19 AM
Electric Fan w/ Variable Speed Controller Installed... bamachem Engine & Drivetrain 0 06-16-2005 11:41 AM
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: Dealer Hunter JPV Photography
