Does it not fit at all?
After I install mine, the one on the left shows a little white strip over to the next column. At first I thought I didn't installed it properly. Buy after several try, I realized it's manufacture's defect.
I don't know if this is the problem you're having. If so, instead of cutting, I just taped over the white strip with black tape. That should solve the problem!
