fog light install 2007 CM
I have figured out that when installing a relay 41-5154 autozone that the factory harness is hot when you turn on your parking lights.The ecu only controls the ground side of the harness.This being said I used the factory harness and grounded the lights at the mount.Did not install a switch,they come on with the parking lights.A switch could be installed on the ground I guess if you wanted one.The mount actually grounds my lights(cheap made in china bling lights)but I also attached the ground wire to the mount.
Also I found a set of Pilot lights at autozone for 40 bucks.Almost identical to the blings.4 3/8 light with a better bracket than I got.I got most of my ideas from the others on the boards and would like to thank them for there ideas and photos
Bill,
Franklin KY
2007 CM SR5 Slate blue.
5.7,4 x 4
Trail FX step bars
JBL 6 disc audio 12 speaker with blue tooth
sunroof,
limo tint all around
linex,
undercover,
electrochromic mirror,
Back up camera drop down monitor,
Bling Lights
