Tundra Solutions Forum
Welcome to the Tundra Solutions Forum.
You are currently viewing our forum as a guest which gives you limited access to view most discussions and access our other features. We're a forum based community of Late Model and First-Generation Tundra owners. We also have forums for most other Toyota Cars and Vans, Trucks and SUVs. Some of our more popular forums are specific to questions about Audio, Electrical, and Wiring, Interior and Exterior, Handling, Suspension and Axles, and of course Tires and Wheels   These, and more Technical and Vehicle Assistance forums are monitored closely by our team of experts, and you will get your best answers when posting questions to these problem specific forums, rather than to your personal vehicle forum. We have a huge archive of information, so a good place to start your visit to the Tundra Solutions Forum is the Search page, or just click the Search link in the navigation bar for a drop-down search menu. There is also a Site Map of the forum.
Once you Register, you might want to make use of the Photo Gallery to post some pics of your ride By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content, and access many other features. Registration is fast and simple so please, join our community today! You can purchase a subscription when you register and gain access to the enhanced features available on our website.
Thanks for visiting the Tundra Solutions Forum, we hope you enjoy your stay.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
Old 01-02-2008, 04:12 PM
Tundradrenalin's Avatar
Be First!
My Dealer : Charles Barker Toyota
2005 Toyota Tundra AC TRD 4WD,
2004 Toyota RAV4 Sport
My eBay Tundradrenalin's Photo Gallery
Last Online: Today 11:35 AM
Age: 30 Posts: 2,930
Tundradrenalin has a spectacular aura aboutTundradrenalin has a spectacular aura about
Default DIY: TruSpeed Install Guide for 2005 Tundra, 4WD
This TruSpeed (#33002) install was performed on a 2005 Toyota Tundra, Automatic Trans, 4WD, Access Cab model.
***NOTICE: this install is vehicle specific.***
Thank you mustang67408 for your unwavering support.
I mounted the TruSpeed Speed Sensor Calibrator in the glove box, routed the loomed wires through the dash, and connected all of the wiring to the Combination Meter. The install requires some minor technical know-how and no specialty tools other than a solder iron.
Equipment Used:
TruSpeed model#33002 by Superlift
#2 Phillips
10mm socket & wrench
16awg eyelet (for ground wire)
solder iron, solder & flux
wire strippers
needle nose pliers
electrical tape
wire loom, about 3ft.
Manufacturer Instructions
Route all the Truspeed wires through the loom before you start.
Solder one end of the connectors to the designated wires of the TruSpeed unit. This will save you some time later.
Remove the glove box.
Remove the Integration Control Panel.
Route the wired loom through the back of the glove box to just below the radio assembly.
Looks like this:
Remove the Combination Meter.
Turn the combination meter around, looks like this:
***at this point, I disconnected the battery***
Remove the two connectors from the back of the combination meter and put the combination meter aside. You will not need it until you’re done.
POWER
The red TRUSPEED wire goes to a good 12V switched power source. I used PIN 24 on CONNECTOR C12 (on back of combination meter) it is a Black/Orange wire. Just "T" tap into the wire. Here’s what it looks like:
SPEEDO
Now you need connector C11 (back of combination meter),
find pin PIN 24, it is a BROWN/Black wire. Cut this wire approx 3 inches behind the connector.
The GREEN TRUSPEED WIRE goes to the vehicle's wire harness end of the wire you just cut.
The YELLOW TRUSPEED WIRE goes to the dash connector end (to Speedometer).
Solder each wire to the designated connection point and cover with the supplied heat shrink tubing.
Here’s the new sequence your truck's speed sensor now has:
Speedometer --> Yellow Wire --> TruSpeed Module --> Green Wire --> Vehicle Harness
GROUND
The black wire needs to go to a good ground; there is a bolt behind the combination meter, use the eyelet and bolt it to the metal dash support. You can’t miss it.
End Result Wire Diagram looks like this:
Reassemble the Combination Meter, the Integration Panel, and the Glove Box. Installation is complete.
Use the supplied Velcro to attach the TruSpeed unit somewhere in the glove box. Make sure the wire loom doesn’t get snagged by the glove box when you close it. I mounted mine just behind the light.
ADJUSTING THE TruSpeed:
This is all subject to what you’ve done to modify the truck: larger/smaller tires and/or new gearing. You may want to refer to the Manufacturer's Installation Instructions, I've posted them in my gallery, the link is in the Equipment Used list.
I went from the stock TRD tires BFG Rugged Trail 265/70-16 to a larger BFG All-Terrain ko 285/75-16. I reset my TruSpeed by turning it CCW 15 complete turns. Then I tuned the TruSpeed for the new tire size by turning it CW 6 ˝ turns. I crosschecked it using a GPS at 30, 40, 50, 60 and 70 mph. The speedo is now calibrated to near perfect.
Install time Start-to-Finish: 80minutes to +120minutes, depending on your technical abilities.
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
My Truck:
2005 Tundra, 2UZFE. 4WD. AccessCab. AT. ex-SR5. Spectra Blue Mica (8M6). TRD. CC. CK. DZ. FE. AW. LD. OF. TO. VP. RP (Royal Purple)
Fabtech Coilovers. 285/75-16 BFG A/T'ko. Goeske Wheel Adapters. TRD drop-in Air Filter. Truspeed Speed Sensor Calibrator. Toytec Diff Drop. CV Boot Mod.
Rear Diff Breather Extension. Fumoto Oil Drain Valve. Debadged (partially). Dechromed. Line-X Bedliner & Mirror covers. 25% Tinted.
eDead Sound Deadener. Alpine CDA-9886. Alpine MRP-F250. Phoenix Gold ZR Components. PETA Hater.
Old 01-02-2008, 05:14 PM
student's tundra's Avatar
My Dealer : Longo Toyota
2003 Toyota Tundra,
1998 Toyota Camry Daily Driver
student's tundra's Photo Gallery
Last Online: Today 01:38 PM
student's tundra is on a distinguished road
Default Re: TruSpeed Install Guide for 2005 Tundra, 4WD
Nice write up . I installed mine sometime ago on my 03 w/ the support and guidance of Victor. Works really well I tuned it to when I added 285x75x16s and then when I regeared to 4.30s, awesome product
2003 Tundra Imperial Jade TRD offroad
Performance modifications
2.5 Revtek Lift, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
Hellwig anti-sway bar w/ Custom Front Range Offroad Quick-Disconnects
4.30 ring and pinion gears, TRD Dual Exhaust, TrueFlow filter, Superlift TruSpeed
Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade
Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Old 01-03-2008, 08:03 AM
Be First!
FYI to whoever reads this write-up:
The model# 33002 is for every Toyota out there, the only thing vehicle specific is the wire color patterns behind the tachy
Student's Tundra, did you notice a slight drop in the idle and cruising RPMs after install? I did, feels so much smoother shifting now. I did change my air filter at the same time though...
My Truck:
Old 01-03-2008, 08:30 AM
RitcheyRch's Avatar
Fellow Tundra Owner
My Dealer : Frontier Toyota
2002 Toyota Tundra
RitcheyRch's Photo Gallery Send a message via AIM to RitcheyRch
Last Online: Today 12:55 PM
RitcheyRch is on a distinguished road
Very nice write-up.
Old 01-03-2008, 01:00 PM
2003 Toyota Tundra,
Nope cant say that I remember a drop in the idle and crusing RPMs but it has been about 2years since the installation. Oh and did think about an install in the glove compartment but decided on underneath the center console instead (easy to get to and consealed )
TRD supercharger
IPT valve body mod
Old 01-10-2008, 06:22 AM
USAFTUNDRA's Avatar
My Dealer : Northcutt Toyota
2005 Toyota Tundra
USAFTUNDRA's Photo Gallery
Last Online: Yesterday 07:27 AM
USAFTUNDRA is on a distinguished road
Default Re: DIY: TruSpeed Install Guide for 2005 Tundra, 4WD
good work and a nice presentation!
I'm not a pilot, but I did stay in a Holiday Inn Express last night!
__________________________________________________ __________________________________________________ _______________________
2005 4.0L V6 SR5 Access Cab _12256 Magnaflow 18" Muffler & 35204 Magnaflow 12" Tip_ _ScanGauge II_ __________________________________________________ __________________________________________________ _______________________
Other Mods:-Disconnected Keyless Entry "Beep"-Missile Switch-Mossy Oak Floor Mats and Steering Wheel Cover-NASTA SS Nerf Bars
Future Mods:-Dynamat Hoodliner-A.R.E LSX Series Tonneau Cover-Sportsman Camo Covers™
Granddaddy Cyberbilly used to say "No one has time to do it right, but they always find time to do it over."
Old 02-02-2008, 06:27 PM
rich29_cal's Avatar
My Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
rich29_cal's Photo Gallery
Last Online: Today 12:45 PM
rich29_cal will become famous soon enough
Great write-up. Thanks.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 02-03-2008, 05:13 PM
RitcheyRch's Avatar
Fellow Tundra Owner
2002 Toyota Tundra
Wish someone would do the same write-up for a 2002 Tundra.
Old 03-18-2008, 09:51 PM
phoenixx's Avatar
My Dealer : Toyota of Temecula Valley
2005 Toyota Tundra
phoenixx's Photo Gallery
Last Online: 03-30-2008 12:12 AM
phoenixx is on a distinguished road
Does anyone know the location and color code of the wires for the Speed Sense and Reverse on the 2005 tundra D-Cab?
Need ASAP.
Many thanks,\
Chris (858)###-####
Web address or wiring diagram would be helpful but location and color will do.
Old 03-19-2008, 06:11 AM
Be First!
Hey Chris, check out these diagrams. They should be of some help.
The first page shows you the Speed Control diagram. The DC wire looks to be a purple wire with a white tracer.
-Andy
My Truck:
Old 03-19-2008, 02:01 PM
My Dealer : Magic Toyota
2005 Toyota Tundra
papayasalad2002's Photo Gallery
Last Online: 03-24-2008 08:14 PM
papayasalad2002 is on a distinguished road
Tundradrenalin - i like those diagrams. I'm searching for the car speed signal wire myself. Need the reverse and the speed wire to install Avic D3 navigation system. Seems that regardless of what navigation system you install you need these two inputs for the Navigation system.
I've located the reverse wire and confirmed with multimeter. Driver lift kick panel there's a gray plug ...it's the black and white wire that I've poked the black lead from the multi meter http://natalisinc.com/05tundradcabreverselightwire.jpg
I'm still a little confused about the vehicle speed signal wire. I don't see the purple/white wire in the diagram as connected to any speed sensor... I'm not good at reading wiring diagrams. I currently have the instrument cluster and glove box out and for access to the ECU wiring harness. If you or someone could clarify for me which wire to tap into from either location for the speed signal I would appreciate it.
Last edited by Tundradrenalin; 05-03-2008 at 09:21 PM. Reason: photo size exceeds 800x600
Old 03-19-2008, 04:57 PM
Be First!
papayasalad2002,
The diagrams I supplied in the previous post were for the combination meter, which is the panel you have the MPH/RPM/Fuel/Temp gauges on.
Here's another diagram for you to browse. Maybe page 338 has your answer.
My Truck:
Old 04-23-2008, 12:21 PM
imjin's Avatar
Lifetime Subscriber
My Dealer : McGeorge Toyota
imjin's Photo Gallery
Last Online: Today 12:14 PM
Age: 40 Posts: 1,253
imjin is on a distinguished road
Would you happen to have the wiring diagram for a 2001 Access Cab?
Mods: Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | Hawk Super Duty Front Brake Pads | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Future: ARB Sahara Winch Bumper | New UCAs & Coilovers | 4.30 Gearing | Mickey Thomas Classic IIs
Old 04-23-2008, 12:28 PM
mustang67408's Avatar
KE7WLF Master of Disaster
My Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Gallery Send a message via AIM to mustang67408 Send a message via Yahoo to mustang67408
Age: 43 Posts: 4,129
mustang67408 is on a distinguished road
E-mail me and I'll map out the wires for you tonight.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
Old 04-23-2008, 12:34 PM
