Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Free Shipping at Buy.com!
FREE Personal Trainer Program
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Factory Battery...how long do they last?", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-08-2008, 06:29 PM
lsturbointeg's Avatar
Dealer : Toyota of Temecula Valley
lsturbointeg's Photo Albums
Last Online: 09-01-2008 09:08 PM
lsturbointeg is on a distinguished road.
Default Factory Battery...how long do they last?
My 2006 DC is only a couple years old and my battery was dead today. The truck did sit for about 2 weeks and I'm wondering if that did it?? Any suggestions?
2006 Toyota Tundra SR5
RCD 6" lift / 5100 bilstein rear shocks / 3" custom body lift / 17x9 Pro Comp 6001 chrome finish / RhinoLining / Husky Black Tool Box / Leer Ladder Rack / 35/12.50r17 Pro Comp Xterrains / Valor IDA-700W 7" WideScreen / AVE AV-1520 15.2" TFT/LCD Flip Down Monitor / 8" Infinity Reference 850w subs / Custom Fiberglass sealed enclosure / MB Quartz DSD216 Discus Components front and rear / Kenwood KAC819 Mono Amp / PPI5440 5 Channel Amp / Power Converter w/ audio/video input
Old 02-08-2008, 08:13 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Hi Volt's Photo Albums
Last Online: Today 05:53 PM
Hi Volt is on a distinguished road.
Default Re: Factory Battery...how long do they last?
A normal automotive battery should give you about 4 to 5 years of service ( reasonable quality ones). Your battery should not have died so quickly ( 2 weeks ) under normal conditions. Could you have left on an interior light or something like that ? Or do you have some accesories that do not switch off with the key ?
The drain from the ECM is not enough to kill off a battery for quite a long time. What you can do is charge it up and take it to a shop and have a load- test done on it, this can give an indication of a weak battery. Most batteries have a pro-rated warranty that may help cover you if the battery shows up to be bad.
Old 02-08-2008, 08:29 PM
Nope! No interior lights left on by accident or anything else. I did have a lil bit of corosion on the negative battery terminal i'll have to clean up.
Old 02-09-2008, 08:34 PM
Big_Al1's Avatar
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
My eBay Big_Al1's Photo Albums
Last Online: Yesterday 09:49 PM
Big_Al1 is on a distinguished road.
Send a message via Yahoo to Big_Al1
Try charging it and cleaning like previously stated.My 05 sat for two weeks after surgery and I thought it wouldn't crank she fired right up.Still running strong 3years 9 days and about 32k miles.Corrosion makes for high resistance.It will probably run fine after cleaning the terminal and charging.
Old 02-11-2008, 01:52 AM
Just picked up my battery charger from the storage. Hooked the battery up and immediately it was reading less than 25% charged. Set the charger to 2amp and it took about 3 1/2 hours to reach 100%. Will reinstall the battery tomorrow since it's already dark outside.
Worst case scenario you guys say it does it again. Defective battery or is it just not able to hold a charge anymore? Possible slow discharge in my wiring somewhere? I am running an aftermarket system with 2 amps.
I know when I use to work at Sears Automotive the battery tech would run a systems charge test and they can tell if there's a slight drain in the electrical system somewhere but can't pin point exactly where?
Old 02-11-2008, 09:47 PM
Big_Al1's Avatar
2005 Toyota Tundra,
To pin point drain you can get a meter and check after turning off truck and disconnect things one at a time until you figure out what is draining your battery.Depending on how many watts you are cranking you may need to invest in an optimum or some kind of deep cycle battery or second battery set up.The system could be not letting your battery fully charge because if the alternator can't supply the amps you need it will pull from your battery which over time will drain it because it will not fully charge.
Old 02-11-2008, 11:21 PM
student's tundra's Avatar
Dealer : Longo Toyota
2003 Toyota Tundra,
1998 Toyota Camry Daily Driver
student's tundra's Photo Albums
Last Online: 09-04-2008 01:55 PM
student's tundra is on a distinguished road.
Just replaced mine last month after 5 years and 1 month of service
2003 Tundra Imperial Jade TRD offroad
Performance modifications
2.5 Revtek Lift, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
Hellwig anti-sway bar w/ Custom Front Range Offroad Quick-Disconnects
4.30 ring and pinion gears, TRD Dual Exhaust, TrueFlow filter, Superlift TruSpeed
Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade
Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
