Tundra Solutions is looking for someone in the central valley who owns a 2007x Supercharged Tundra that we can borrow to take pictures of and use in a story. If you would like to help please send a PM to TundraSoul or send us an email. We will pay you for your gas and time to meet us at our office in Clovis. Thanks.
Electrical & Computer SystemsDetails discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Dash lights not working...and all fuses are OK", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
So I installed the Sirius FM transmitter into my 2006 Tundra DC today, and while I was wiring into the factory JBL head unit I shorted out the dash lights and navigation dimmer (basically everything that turns on when you turn the lights on). I replaced fuse #45 (Panel 7.5A), which solved my navigation problem (it now switches to night mode when I turn the lights on). However, the dash lights are still dead, and I have tested every single other fuse with zero success.
Has anyone experienced this before? Is there another relay/fuse that is hidden somewhere in the dash? Doesn't seem likely, but I'm out of ideas at this point. Any suggestions would be awesome.
Re: Dash lights not working...and all fuses are OK
I know this sounds obvious however don't forget to check the dash light dimmer control. It's the scroll wheel usually on the left side of the dash. slide rotate it up and down to see if that's the issue.
Well on my 07 I did something similar. Now I bet are trucks are different to some degree but in my case the same thing happened. My first stupid mistake was wiring up stuff with the battery conected, will NEVER do that again.
Turns out the short fried a relay that is in the insturment cluster, one that is also tied into the odometer, which makes things even more tricky (read expensive) Dealer had to order a new cluster, which has to be pre programed by the manufacturer (dealer can not do it) for your current mileage. This is what happened to me at least. They changed the cluster and its fine now.
__________________ 2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Pioneer 10" sealed sub box, Clarion 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
I remember someone else doing this and it ended up being the dash dimmer control. Sorry but I don't remember what they paid to get it fixed. You might try a search and send a pm to whoever it was. Good luck.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner
