Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Viper 5701 LE Responder", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-24-2008, 06:59 PM
RisingSun's Avatar
2007 Toyota Tundra Slate Limited
RisingSun's Photo Albums
Last Online: 08-14-2008 12:00 PM
RisingSun is on a distinguished road.
Default Viper 5701 LE Responder
Wasn't what you would say tickled with the Viper 5900 so today I had the 5701 installed at a professional shop. Has a few more features and alot easier on batteries. Price with all sensors (except proximity) was $525. So considerably cheaper than the 5900 with two remotes. Even had my hard Undercover tonneau cover sensored as well. Very pleased at this point.
The wiring directions for our truck (2007) were a little vague on the ignition wires but they got it hooked up fine.
5.7 Crewmax SR5 4x4 Silver Sky Metallic
TRD Wheels
Undercover Hard Tonneau
Carriage Works Polished Billet Grill
Spray in Liner
Westin Tube Steps
KC 35w Amber Fog Lamps
Weathertech Visors
Sirius Satellite
Flowmaster 50 SUV Dumped
JVC KW-AVX810 Head
Kicker 12" Sub
Boston Acoustic Speakers
Boyo Rear Camera
Extreme Amp
Putco LED Dome Lights
Chrome Door Handles
60" Fire and Ice rear LED lights
Recon 62" Side Running Lights
Viper 5701 LE Alarm and Remote Start
(all sensors except proximity)
Truxxx 3/1 Lift
Xenon H11 8000K HID Lights
** Sunroof being added soon
Old 04-25-2008, 04:22 PM
unionxc's Avatar
Dealer : Jim Norton Toyota
2003 Toyota Tundra
unionxc's Photo Albums
Last Online: Today 06:55 PM
unionxc is on a distinguished road.
Default Re: Viper 5701 LE Responder
Alright, so you you like it. I have been looking at one of these, but there so new i wasn't sure yet.
2003 AC SR5 Black-Aries Bull Bar-Chrome Nurf Bars & Bed Rails-Clear Corners-Alpine IVA W205-CDT EF61CF-JBL LCA504-Q-logic with 2 ED 9Kv.2s-Alpine MRP-M650-Tsunami 2 Farad Cap-Magnaflow 11226 muffler with a Magnaflow SS tip 4" outlet
Old 04-25-2008, 11:07 PM
RisingSun's Avatar
very user friendly and has alot of programming features. The "ghost lights" are pretty cool and good range (2000 ft).
TRD Wheels
Spray in Liner
Westin Tube Steps
Weathertech Visors
Sirius Satellite
JVC KW-AVX810 Head
Kicker 12" Sub
Boyo Rear Camera
Extreme Amp
Chrome Door Handles
Truxxx 3/1 Lift
Old 04-28-2008, 11:10 AM
RisingSun's Avatar
Originally Posted by Toxarch View Post
What didn't you like about the 5900? I'm in the market myself and like the idea of the visual display of the two way remote. I know the 5701 is also 2 way, but with a lower range. Since you've had both, mind saying what you didn't like and how the 5701 is better? Also, what was the battery life on the 5900? I'd hate to get one and be buying new batteries all the time.
The 5900 is a good system. However, I am one of those people who can not have anything with an LCD screen in my pocket. Always ends up getting scratched up (this one did in less than a week). It's also bulky compared to the 5701 and went through a set of batteries in 10 days. This may have been in part to all the playing I was doing with it. Battery life on the 5701 is three to 6 months. The 5701 will check the temp inside the vehicle for you as well as activate the rear window defroster when it's below 55 degrees if you program it that way. Also there is a "silent mode" that will not sound the truck alarms but will set off the pager on the remote.
If you need the LCD to show you what's going on then by all means get the 5900. The 5701 will do all those things and more by the color and amount of LCD's that light up (easy to memorize). The 5701 also utilizes a new "supercode" instead of code hopping that all of the other Viper systems use.
Go to Viper.com and download the owners manual for each and you will see more of the differences. The 5701 is also cheaper by nearly $175. The two stage sensor is sensitive enough that you don't need a prox sensor.
TRD Wheels
Spray in Liner
Westin Tube Steps
Weathertech Visors
Sirius Satellite
JVC KW-AVX810 Head
Kicker 12" Sub
Boyo Rear Camera
Extreme Amp
Chrome Door Handles
Truxxx 3/1 Lift
Old 04-30-2008, 02:11 AM
RisingSun's Avatar
Thanks for the info. I might get the 5701 LE just because of the long battery life compared to the others.
I noticed the valet switch, antenna, and LED are all on the same device. Kinda odd but apparently it's done for ease of install. Can I ask where they installed yours at? Could you post a picture?
It is all contained in the antennae which is on the windshield behind the rear view mirror. The valet switch is actually a button that you would not know is there unless you owned it. It can be programmed to alarm the system again once the truck is parked. Or if you open the door without your remote (if you happened to lose it) you can also deactivate the alarm by pressing the valet button a set amount of times within 5 seconds.
Then if the ignition key is not used within a programmed amount of time the alarm will go off. The blue led pulses every second just bright enough to flash a soft blue beam on to the driver seat area. Easily seen at night or you can cover the led if you don't want it to be seen. I am impressed with the programming abilities of this system. I'll try to get a picture tomorrow night and post it for you.
TRD Wheels
Spray in Liner
Westin Tube Steps
Weathertech Visors
Sirius Satellite
JVC KW-AVX810 Head
Kicker 12" Sub
Boyo Rear Camera
Extreme Amp
Chrome Door Handles
Truxxx 3/1 Lift
Old 04-30-2008, 05:02 PM
unionxc's Avatar
2003 Toyota Tundra
Yea that would be great, it sounds good, and its on my list to do.
Old 05-01-2008, 01:11 AM
Dealer : Toyota of Puyallup
MMichaelJJ's Photo Albums
Last Online: 10-07-2008 10:53 AM
MMichaelJJ is on a distinguished road.
I know we don't live in the same place, but where did you get yours installed (Major retail store)? I went to a local car audio / security shop, and the guy quoted me something like $800-$900 for it. I think he listed off 5-7 additional charges.... had to diode each door... parking light flash... factory alarm bypass... immobilizer... he just kept listing charges.
That was for the Clifford model which is basically the same thing. They had the alarm listed for $499, which included basic install.
Old 05-01-2008, 03:10 AM
RisingSun's Avatar
I found the Viper online for $245 and the Clifford for $265. After seeing that price and the quotes above, I think I am going to install it myself. They claim it's an easier install than other alarms.
I'll look for those pictures posted tomorrow.
Good luck on doing your own install. Mine was done at a professional shop where I had my JVC head unit system installed. They are an authorized dealer and it took the tech quite a few hours to do the install. He also used a new bit writer that is needed for the 5701. This allowed the oem alarm to be fully integrated in with the Viper system. You do not need a valet key in a box for the 5701. It recognizes the Tundra ecm on its own. There was also alot of misleading info on Toyotas end about which green wire on the ignition switch as there are 4 of them and they all read ignition. Finally had to remove the steering column to confirm the wire off the tumbler. Plus the ecm wiring was confusing as well. It was the very first 5701 my shop has installed due it being such a new item from Viper.
Having an authorized shop do the install ensures the warranty on the system. Again with tax it was $529.38 exactly and tax here in Maryland is 6%. I have a sensor on the tonneau cover, all doors, hood switch, tilt sensor and glass break sensor. With the dark tint it was advised not to do the prox sensor. $800 seems outrageous and you should check around at another authorized Viper installer.
$250 or so online is right but that is without tilt, glass break, prox or any of the optional sensors. The sensors ballpark around $25 or so each.
Good Luck
TRD Wheels
Spray in Liner
Westin Tube Steps
Weathertech Visors
Sirius Satellite
JVC KW-AVX810 Head
Kicker 12" Sub
Boyo Rear Camera
Extreme Amp
Chrome Door Handles
Truxxx 3/1 Lift
Old 05-01-2008, 09:18 PM
unionxc's Avatar
2003 Toyota Tundra
I with you Toxarch, I think i am going to try and do it myself. But i didn't know that glass break and tilt were extra, do you know the model number or what those look like. The glass break i definitely need.
Old 05-01-2008, 11:03 PM
RisingSun's Avatar
The glass brake sensor is #506T, the tilt is #507M. The window control module if you want it is #530T. It will automatically close both your front truck windows when you arm the system.
TRD Wheels
Spray in Liner
Westin Tube Steps
Weathertech Visors
Sirius Satellite
JVC KW-AVX810 Head
Kicker 12" Sub
Boyo Rear Camera
Extreme Amp
Chrome Door Handles
Truxxx 3/1 Lift
Old 05-23-2008, 04:08 PM
Dealer : Vandergriff Toyota
2007 Toyota Tundra White LTD DC 5.7 4x2
wleeb's Photo Albums
Last Online: Yesterday 01:14 AM
wleeb is on a distinguished road.
So the main thing that is needed is to have the 5701 LE programmed for the Tundra ECM. To do it myself, I would need one of their programmers which is about $80 on ebay. I'm trying to see if one place will program it for me before they ship it out. If they will, then I'll buy it and do the install myself. If not, then I have to find a local installer with a DEI programmer who will program it for me.
Hey tox did you buy a programmer, have it programmed or use a local shop? I'm interested in the same unit.
-wleeb
Old 05-23-2008, 06:40 PM
I went with that. It's really the one I wanted from the start.
Do you have the CSPro installed and if so how do you like it?
-wleeb
