Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Wiring for rear camera monitor", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-13-2008, 05:02 PM
Dealer : Coggin Toyota Scion of the Avenues
cwaldrep's Photo Gallery
Last Online: 05-14-2008 07:46 PM
cwaldrep is on a distinguished road.
Default Wiring for rear camera monitor
Installing a rear camera system in a 2006 Tundra DC. The monitor has a red (+12v), black (grd) and a blue (reverse sensing) wire to hook up under the driver's side kickplate. I looked and searched for a wiring diagram with no luck. Could someone point out which wires I should be splicing to. Thanks a lot.
Chuck
Old 05-13-2008, 11:18 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Gallery
mustang67408 will become famous soon enough.
Default Re: Wiring for rear camera monitor
You need connector BB5 pin 9, it is a RED wire/with a Black Stripe.
It is located under the drivers seat. The wire comes from the back up light relay (B3) which is under the drivers side dash. You can trace the wire and tap into it wherever you feel it should be.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
Old 05-14-2008, 07:46 PM
Thanks for the help. Found that wire and after some trial and error, figured out a way to hook up the camera. I wired the camera through the trailer wiring harness in the back and found out that I can't have power to that camera with both the brakes applied AND released. I had to choose one, so I wired it for the camera to operate when the truck is in reverse AND the brakes are applied. I'm sure there's a wire back there somewhere that is powered regardless of brake application, but I didn't have time to test every one. Anyway, thanks for the info. It helped out a lot.
Chuck
Old 05-14-2008, 11:16 PM
2002 Toyota Tundra,
In your 7 pin trailer socket PIN 2 should be HOT (12v) all the time with the engine running. It is used to charge the batteries on a TRAILER.
The wire coming out of the socket is BLACK then goes to a connector just above the rear bumper (BK2). The wire then turns into a BLUE wire going all the way to the front of the truck to the BATT CHARGE RELAY.
This wire, should give you a constant 12v with or without your foot on the brake and the camera should work all the time in REVERSE.
23 yrs with TOYOTA
K.I.S.S.
Bookmarks
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: DealerHunter JPV Photography
