Electrical & Computer SystemsDetails discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Lights & locks just quit", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Help, my daytime running lights, automatic light control, high beams, fog lights, and door locks all just died. The only things that do work are the parking lights and low beams if turned on manually, the courtesy lights (but not the dome lights), and each individual door lock if operated manually by lever or key. Other systems may be involved, VSC won't switch off, and I don't think it's working. This is a 2001 Sequoia Limited which until this week had been problem free. I've inspected and tested every fuse, all fine. Hooked it up to a buddies computer, no codes. The only place I can see that these systems overlap is the body ECU, but I hate to replace it on a hunch. Any thoughts or suggestions?
How are you ?
We are manufacturer of led household bulbs and autobulbs .Project lamps . 1.)Led household bulbs:
MR11 9LEDS .G4 Bulb .
MR16 1W,3W,3*1W .
GU10 1W,3W,3*1W ,
JDRE27 1W,3W,3*1W .
E14 1W,3W,3*1W .
PAR20 3*1W .3*2W
PAR30 5*1W .7*1W .
PAR38 12*1W .
(12V or 85-265V .)
Low power MR16 ,GU10 With 12LEDs.with reflector ( 0.72w) .
PAR30 with 60LEDs( 3.6W).PAR38 With 108LEDs .
2) Led deocration bulbs .led wall washer ,led underground lamps .Led linear lamp
3) Led autobulbs : T5Wedge .
. T8Wedge.(T8 Concave BA9S )
T10Wedge(T10BA9S) ,T15Wedge,BA9S ,3-LED ,4LEDS.5LEDs.
Super Festoon 33mm ,37mm 42mm 44mm
(.single chip .3chips) .red,blue, ,cool white (6500k) .warm white (3000-3200k).
.T25,18,27,36LEDs .Superflux tower 13,20LEDs.
BA15S ,BAY15D ,BA15S ,etc .
4) The delivery cost will depend on your order ( weight of your order )
5)We never ignore small orders .
We provide Time warrenty : One year ( all LED products )
I don't know anything about the Sequoia, but was wondering if you found a solution? Are you fixed?
BJ
Rep Points?
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages,Black-rebadged. was stock 31K on 5/9/05, now 56K
*Moto Metal M0951 Gloss Black 17 in. Alloys *SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
*Bilstein HD Shocks, F&R *Hellwig Rear Sway Bar & Helper Springs *TCS Poly Steering Rack Bushings *Wheeler's Front Sway Bar Bushings *Timbren SES Kit, Front & Rear *
