Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Rain sensor upgrade", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 04-12-2003, 07:37 PM
Dealer : Jim Lynch Toyota
2006 Toyota Tacoma
Mudog715's Photo Gallery Mudog715's Photo Albums
Last Online: 06-19-2007 09:02 PM
Mudog715 is on a distinguished road.
Originally posted by davecsu
Mudog, have you order the rain sensor yet? If so, which one did you get?
The dimmer knob would be cool. You have to post some pictures after you're done.
Regarding the integration to the factory switch, the person from Rain Tracker told me it was difficult for them because of the way Toyota is setup. It's possible with some of the domestic cars, because they have easier access. It would be really interesting if you can integrate it.
The RainTracker, while cool, is not high on my list of priorities for the Tundra right now. I'll probably get to it in 6 months or so. Full-automatic up/down/vent for the power windows and my PowerSlider and full auto climate control are more important to me.
Putting the control where the dimmer knob is should be very easy for you to do. The little panel that the dimmer attaches to (with the fog switch) just pops straight out after you remove the lower dash cover. The dimmer knob pulls off and the switch is held to the panel with a single nut around the shaft.
Wiring it into the stock wiper delay will be harder, but I don't believe impossible. That's why I would avoid drilling a new hole because when I get around to doing the RainTracker, that's going to be my goal -- to use the stock delay control. The reason why Toyota's are difficult is because Toyota builds the electronics for the wiper delay directly into the wiper switch. Therefore, connections between the delay control and delay electronics are not external to the switch -- and it's these connections that must be intercepted to use the delay control for some other function. On other makes, the delay electronics are either built into the "Body Computer" (Ford, Honda, Chrysler, Nissan, Mitsubishi) or built into the wiper motor itself (GM). This means the delay control signal from the switch to the electronics can be easily intercepted in the wiring harness between the switch and the BCM/wiper motor. That was simple, wasn't it? ;-)
  #17 (permalink)
Old 04-13-2003, 12:26 AM
Inactive Account
davecsu's Photo Gallery davecsu's Photo Albums
Last Online: 06-11-2004 07:53 PM
davecsu is on a distinguished road.
Question Auto Climate Control
Mudog, thanks for the info!
When you mentioned auto climate control, are you thinking of the ones from Sequioa? Would that be difficult to do? How about cost? That would be cool!
  #18 (permalink)
Old 04-13-2003, 02:45 AM
2006 Toyota Tacoma
Lightbulb Re: Auto Climate Control
I originally looked into transplanting the system from the Sequoia, but found a direct transplant would be impractical for several reasons:
1. The Sequoia "Integration Panel" (center control panel) lacks provisions for some things needed on a Tundra: Passenger Airbag Keyswitch & Light, 4WD Low range button and different labeling for the Cargo Lamp button (the function on the Sequoia escapes me at the moment, I think it's "VSC off").
2. The panels on both the Tundra and Sequoia interface to the engine ECU and I can't be certain that the Sequoia panel will "talk" to a Tundra ECU properly. The function of the signals between the two systems are not clearly defined in the service manuals.
3. The panel on the Sequoia also interfaces to the instrument cluster with additional 2 lines not found on a Tundra, so there is an issue if I can fool it into functioning wihout those lines.
4. The Sequoia panel would also require all Sequoia parts for the rest of the system, which include: Temp Control Amp ($450), Blower Control ($147), Air Mix Servo ($97), Air Mode Servo, Sunload sensor, In-car sensor, Ambient sensor, and the control panel itself. New, these parts are in excess of $1,500 from a Toyota dealer (wholesale pricing, BTW, lower than the "discounted" price places like Carson charge us). That cost makes it impractical. Finding the parts at a junkyard are near impossible -- it's hard enough to find a wrecked Tundra, let alone a Sequoia! And, again there is the possibility that they may not function without a matching Sequoia gauge cluster and engine ECU!
So, the alternative I came up with was designing my own system from scratch, using a few pieces from the Sequoia system (Air Mix Servo & Blower Control) and reusing the stock Tundra Integration Panel. It would also use the outside temp sensor included with the comp/temp mirrors as the ambient sensor, add an in-car sensor & sunload sensor.
The Integration Panel would remain stock in appearance, with the three rotating dials, however the following functions would change:
1. The blower control (Off-Low-M1-M2-High) would become Off-Low-Auto1-Auto2-High). As implied, in the two "Auto" positions, the blower speed would be controlled automatically at one of 32 (!) discrete levels. The speed would ramp up and down, almost imperceptably, as needed to maintain the cabin temperature. The speed would also be increased 10% in the "Auto2" position, and increase up to 20% based on the signal from the sunload sensor. The Low position would yield a fixed speed approximately between the current Low & M1 speeds, and the High position would fix the speed at maximum.
2. The temp control (Cold---Hot) would be replaced with a potentiometer and become the set temp. dial. Markings would be Cold---65(9o'clock)--75(12o'clock)--85(3o'clock)--Hot. The temp dial position would be read by an ATC (auto temp control) computer of my own design and would set the temperature the system would maintain. At the dial extremes (full Cold or full Hot), the system would be "overridden" and drive the Air Mix Servo to either the full hot or full cold positions. Otherwise, the ATC computer would vary the Air Mix Servo to maintain the set temperature. I considered replacing this dial with 2 buttons and a digital readout, but decided against it because such an arrangement would require the user to look at the display to confirm changes -- a potention distraction while driving. Almost all the stock ATCs these days went back to a rotary knob for temp setting for this reason.
3. The "Recirc" button would operate as stock with 2 exceptions: 1. In the "fresh" position, the ATC computer would switch to "Recirc" automatically in situations when "Max A/C" is needed (various criteria would be considered, including outside temp, inside temp, and the temperature rate change). 2. In the "recirc" position, recirc would only be allowed for a maximum period of time, which would vary if the A/C was on vs. off, then it would automatically switch back to "fresh" This is the way most stock ATC's operate and they do this to prevent fogging of the inside windows in cooler, humid weather and to prevent the formation of "musty" smells in the A/C ductwork and evap. coil.
4. The A/C button would operate as stock. The ATC would vary it's operating strategy when on vs. off.
5. The Mode dial would remain manual. This is to keep the system simpler and costs down. I did some quick figuring and adding full-auto mode control to the system would add $200 to the total cost. For me, at least, I'm most interested eliminating the "fiddling" of the manual system so auto blower and temp control are my goals. Having to occasionally rotate the dial from panel to floor is no big deal. Also, some auto systems don't deal well with situations where the outside temp. is close to the desired (set) temp -- they may not pick the mode setting that the driver prefers, so the driver ends up overriding it anyway. One thing that would be automated is the "Defrost" (full clockwise position) -- in that position the ATC computer would override the "recirc" button to "fresh" and reduce the rate at which the blower speed reduces as the system approaches the set temperature (ie. keep the speed "higher, longer") to aid defrosting. It would NOT force the A/C on, as the stock Tundra system does, however if you performed the mod to disable the stock "defroster linked A/C" (as Toyota calls it) you will have to reverse the mod for the ATC to sense the "Def" mode correctly.
A couple of additional, optional functions (user enabled):
6. The A/C can cut out under WOT and the cut-out time limit could vary according to temp demand (hotter outside, less cut-out time).
7. When A/C was on and the vehicle stopped and turned off, the system would switch to "fresh" and run the blower at medium speed for a few minutes to purge condensation from the evap coil. This will help reduce the mold build-up that causes the musty smells. The time would vary automatically according the circumstances (ie. if the system was operating in Recirc prior to shut-off, then the "purge" time would be longer).
8. If the vehicle is equipped with a remote starter and the remote start was activated, the system would automatically switch on the A/C if the driver left it off but the outside temperature is 5 deg higher than the set temp.
9. Upon unlocking the vehicle with the keyless entry or alarm, and the interior temperature is more than 5 deg over the set temp, the system would enter the purge mode described in #7, except at High speed and only until a door was opened or 60 seconds passes, whichever comes first.
10. A control output would be provided to activate (user-added) heated outside mirrors based on ambient temperature and other conditions. The output would "cycle" as needed to maintain the mirrors defogged, but prevent overheating of the mirror elements. In other words, "automatic heated side mirrors."
11. A control output would be provided to activate (user-added) heated seats based on ambient temperature, as soon as either 1. the truck is unlocked or 2. remote start activated. In the case of activation with an unlock, they would shut off within 5 minutes if a door isn't opened and truck started.
12. Because the system has a sunload sensor, it would double as an ambient light sensor and outputs would be provided for full auto on/off control of the headlights.
My goal is to be able to put a kit together in the $500-600 range. Because of the cost of the individual parts, I doubt I'll be able to get it much lower. If I can't get it down to $600, then I doubt I'll make a kit because I'm guessing it would be prohibitively expensive for most people.
  #19 (permalink)
Old 04-13-2003, 03:22 AM
2006 Toyota Tacoma
Default Re: Re: Auto Climate Control
I forgot to add the option #9 can also compliment other vehicle add-ons such as the RainTracker and Full Auto Window Control like this:
9. Upon unlocking, meeting the conditions previously described ... the system would enter purge mode. If equipped with auto windows, the windows would lower to the "vent" position or previously "memorized" position when the vehicle was last stopped (i.e. if they were fully down when stopped, they would return to fully down). If equipped with the RainTracker, and rain was detected, then the windows would remain closed or would close if rain was detected after the windows were already opened (this would function even if RainTracker were "shut off" for auto wiper control). Upon entering the vehicle and turning the key on, the windows would either remain in the opened position (if previously open) or return closed (if previously closed) after approximately 30 seconds (depending if the A/C was on and what the interior/outside/set temperatures are).
  #20 (permalink)
Old 04-18-2003, 03:17 AM
Inactive Account
I received the rain sensor today. It will be my project for this weekend. I hope for some rain after I install it. So I can test it and post the result.
  #21 (permalink)
Old 04-24-2003, 10:28 PM
Inactive Account
Thumbs up Works like a charm
I finally installed the rain sensor today. When I was working on it, it was raining outside. Ironically, when I finished installation, the rain stopped. So I had to get out the hose to test it. It works like a charm. The wiper speed is automatically adjusted according to the amount of rain on the windshield. If there's no rain, it stops wiping. Best of all, it can be override for manual operation. I love it!
I bought the optional sensitivity control (XC-1), which is mounted on the steering column below the wiper switch. The sensor itself is mounted next to the rearview mirror. What's most time consuming was taking all the panels off to run the wires. But it's worth it!
  #22 (permalink)
Old 04-25-2003, 01:18 AM
Inactive Account
If anyone is interested in this upgrade, I can consider of doing a write up.
  #23 (permalink)
Old 04-25-2003, 04:40 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Gallery nhparrot's Photo Albums
Last Online: Today 01:51 PM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
davecsu
Would make an excellent addition to the "Garage" and candidate for "Mod-of-the-Month".
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
  #24 (permalink)
Old 04-25-2003, 08:13 AM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Gallery SATundra's Photo Albums
Last Online: 08-01-2008 09:58 PM
SATundra is on a distinguished road.
Originally posted by nhparrot
davecsu
Excellent idea. Hope you took some pics.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
  #25 (permalink)
Old 04-25-2003, 11:26 AM
Inactive Account
davecsu
Will do!
How do I post/submit a mod?
  #26 (permalink)
Old 10-03-2003, 02:57 PM
PoorTruckOwner's Avatar
PoorTruckOwner's Photo Gallery PoorTruckOwner's Photo Albums
Last Online: 06-28-2007 05:42 PM
PoorTruckOwner is on a distinguished road.
Default Can it be used for a sunroof?
HI, Hate to rehash an old thread, but could one of these be used to control a sunroof?? I have a sunroof in my '94 Jeep grand cherokee that has a rain sensor on it. Closes when it rains.. Also vents automatically when interior temp reaches 90 and closes automatically at 65 . Sure miss not having this inmy Tundra..
  #27 (permalink)
Old 04-15-2008, 01:47 PM
Dealer : Canyon Creek Toyota
2005 Lexus GX470
nkostaki's Photo Gallery nkostaki's Photo Albums
Last Online: 07-21-2008 03:56 AM
nkostaki is on a distinguished road.
Default Re: Rain sensor upgrade - Raintracker
This seems to be a very old thread. Has anyone bought and installed the Raintracker auto wiper system in the meantime? I have one on order and would very much appreciate some help to integrate its operation into the factory wiper stalk.
Thanks,
Nikolas
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography Consumer Electronics Hunter
