Old 09-26-2008, 02:25 PM
Remmy700P's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 12:28 AM
Images: 18
Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence.
Remmy700P's Photo Albums
Question Inverter Project Help Needed!
I would like to run A/C power to the aluminum bed box in my 2002 Tundra V8. I need help figuring out the best wiring/mounting solution.
I'd like to have access to A/C power for low-wattage lights, radios, small air pumps, cell-phone recharger, and maybe a coffee machine. No blenders, hair dryers, TVs, or other high-torque motors etc would be used.
Here's my ideal specs:
1. Inverter mounted externally
2. Not sure about min size (800W? 1500W?)
3. Two A/C outlets accessible from inside the bed box (maybe cut outlet holes in the box for the plugs with waterproof covers??)
4. Cutoff switch to disconnect the inverter from the battery
5. Power available without the engine running
Q: I've read members recommending installing the larger inverters in the engine compartment close to the battery due to heat buildup issues in the cab, but wouldn't the high ambient heat generated by the engine be an issue as well?
Q: If the inverter IS mounted close to the battery, is it possible to run a cable to carry the 110-120V from the inverter back to the bed box to a waterproof junction box to mount the power plugs in?
Would this address my requirements? It has thermal protection, low battery shutoff sensor, and some sort of ethernet-based remote on/off system: Northern Industrial 1500 Watt Inverter — Model# 11150 | Modified Sinewave | Northern Tool + Equipment
Any recommendations as to inverter brand, size, mounting options, and wiring solutions would be greatly appreciated.
Thanks all!
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Step Bars | Kobalt LP Bed Box | FR: Daystar 2.5" Lift, RR: Wheeler's 1" Block
LT265/75R16 Nitto Terra Grapplers 119Q 8-ply | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
Mobil-1 Syn 5W-30 | Mobil-1 Syn ATF | Magnefine ATF Filter 3/8" | NGK Iridium IX Plugs #BKR6EIX | Russell Speed Bleeders #639560
Josh's Billet Wing Window Latch Upgrade | CBMTA Member! | 3/1/2009: 49,693 miles
* * * I highly recommend Auto-Rx for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY * * *
"I finally found an honest mechanic. He honestly doesn't know how to fix anything."
Old 09-27-2008, 08:55 AM
rambrush's Avatar
Ever the explorer
Dealer : Findlay Toyota Scion
2006 Toyota Tundra,
2003 Toyota Avalon
Last Online: Yesterday 10:33 PM
Images: 103
rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold. rambrush is a splendid one to behold.
Send a message via AIM to rambrush rambrush's Photo Albums
Default Re: Inverter Project Help Needed!
There is much more info available on this subject over here Power Systems: 12v, Solar, Gen. - Expedition Portal Forums
Bet you will find something.
ARB Sahara,Front Springs www.coilsprings.com Firestone Ride-rites 2245, Hell roaring technology dual battery setup, Wrangler dual battery tray, (2) Odyssey PC1200T batteries, Tru-speed recalibrator, Toyo open country MT 265x75x16's, USA Spec PA-15,AmSteel 7/16 x 90' synthetic winch line, 100' AmSteel 7/16 extension rope, Fumoto quick drain #F103N.
Future Ideas
Winch Warn 16.5ti coming soon..
Sliders Stubbs
Lockers ARB
Viar 460c w twin 2.5 gal tanks
255 x 85 x 16's
4:56 gears
Skid row skid plate package
Old 09-27-2008, 11:04 PM
Remmy700P's Avatar
2002 Toyota Tundra,
Images: 18
Red face Re: Inverter Project Help Needed!
No real help there. I need more pointed answers, specifically to the following:
1. I've read from the inverter manufacturers that they do NOT recommend installing inverters under the hood due to moisture and/or ambient heat issues degrading performance, and they strongly recommend that the leads from the supply battery to the inverter be as short as possible, i.e. 6-12" (with one saying 5' max). Well, that doesn't allow a permanent mounting position anywhere BUT the engine compartment (inside the cab not being usable to due to the aforementioned heat buildup isses...) So where are you guys doing your permanent installs?
2. Is there an inverter wattage rating that above which would mandate a dual-battery setup due to the drain level, i.e. 1200W? 1500W?
I'm trying to avoid having the inverter just sitting loose in the bed box and having to connect all the wiring from the battery just to run a damn coffe maker!
Any help would be great here guys. I'm looking for real-world installs, experiences, and things I definitely should avoid doing.
Thanks in advance.
Old 09-28-2008, 08:41 AM
rambrush's Avatar
Ever the explorer
2006 Toyota Tundra,
2003 Toyota Avalon
Images: 103
I see a couple of options:
If the invertor leads can not be run long distance bring the power to it.
Run large cables 10ga = 30amp which should be sufficent. But if its a longer run drop down in size say to a #6.
This hot lead will run to a load center circuit breaker/fuse buss. Run a seperate ground to the frame if possible.
Then you would be in compliance with a short run.
I would suggest a tru sine wave vs a modified to run computer items and some battery chargers..
Ambulance and emergency vehicles utilize inverters and keep them inside there cabs due to heat.
Future Ideas
Sliders Stubbs
Lockers ARB
255 x 85 x 16's
4:56 gears
Old 03-13-2009, 10:51 PM
masterofstuff's Avatar
Dealer : Tri County Toyota
2004 Toyota Tundra Double Cab
Last Online: 01-22-2010 11:00 PM
masterofstuff is on a distinguished road.
masterofstuff's Photo Albums
I actually put a 1500/3200 watt inverter into the bottom portion of my center console. I put the duplex outlet, after some modification, where the small recessed tray in the back was. I ran 2ga wire up and out the grommet on the passanger side to my auxillary battery.
I removed the stock air box and put in a custom cold intake which opened up a lot of space for the auxillary battery.
It was a tight fit for the inverter, but it fit. Just remember to put some well placed out of sight vent holes.
Old 03-19-2009, 12:42 AM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Yesterday 03:39 PM
Images: 54
hofkamp83 is on a distinguished road.
hofkamp83's Photo Albums
for what you want to run a 400 watt would be fine. i have a 400 watt and run a small tv and labtop without problems. modified sine wave is fine because most of the sensitive electronics have the adapters that convert the 110 down to dc volts anyway. i would mount it in the cab just to keep it protected to the elements. just remember the farther away the larger the power cable you will need and then ground to like a seat mount. then i would get some household wiring (14 gauge would be fine but would recommend 12 gauge) with the flexible conduit and run that to back to a weatherproof outlet box.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Tags
battery , electrical , inverter , power
