replacement fixture similar to cargo lights
+ Reply to Thread
Results 1 to 10 of 10
Thread: replacement fixture similar to cargo lights
  1. #1
    Supporter frankie stockboy is on a distinguished road. frankie stockboy's Avatar
    Join Date
    Feb 2002
    Location
    Portland, Maine
    Posts
    53
    Liked
    0 times
    Rep Power
    12
    Question replacement fixture similar to cargo lights
    What I want to do is put a light under my tonneau lid and have it funtion identical to the cargo light, which has been rendered useless by the lid. I don't need it to be like daylight under there and I'd like to do it as simply as possible--cut the wires to the cargo light, extend them to the inside of the bed, then connect them to a light fixture similar in draw to the cargo lights.
    The cargo light is two 18 watt bulbs. Can anyone suggest a similar fixture that would work well here? It doesn't need to be weatherproof, but definately needs clear lenses. I've come across a few options, but none I really like yet...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter JnEsPappa is on a distinguished road. JnEsPappa's Avatar
    Join Date
    Jul 2002
    Location
    Lafayette, LA
    Age
    43
    Posts
    1,652
    Liked
    0 times
    Rep Power
    12
    SATundra has done some nice work with under the cab lights, but I have NO idea how he did it. Maybe give him a PM
  4. #3
    Join Date
    Feb 2002
    Location
    Portland, Maine
    Posts
    53
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Yeah, I looked through his mods and contemplated a similar setup, but inside the bed. The 55-watt lights that he used are overkill for what I'd like, though. I want to be able to, say, go into the bed of my truck at a dark campground and be able to see, but not flood the bed with headlight-quality brilliance.
    Of all the fixtures I've found, it seems like I've got two options--the overly bright, driving-light fixture or the wimpy, frosted plastic dome light fixture. I'm on a mission to find something inbetween.
  5. #4
    Rookie glenn233 is on a distinguished road. glenn233's Avatar
    Join Date
    Nov 2002
    Location
    New York
    Age
    49
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    check cabelas at cabelas.com look under truck and atv they have pick up cargo box light set.
  6. #5
    Lurking Member nymand1 is on a distinguished road. nymand1's Avatar
    Join Date
    May 2003
    Location
    Wausau, Wisc.
    Posts
    29
    Liked
    0 times
    Rep Power
    11
    Default tonneau lights
    I've been looking for this solution too. I've thought of two small LED lights, mounted on the sides of the bedliner, flush with the outside surface. The hang-up might be the wiring. What do you do, drill through the bed to tap into the existing cargo light wiring? I don't think so. I will continue to ponder this.
  7. #6
    Assistant Administrator nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,435
    Liked
    11 times
    Rep Power
    1671
    Wire it through a grommit under the driver's seat, along the rail under the bed and into the bed via the driver's side tailight.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  8. #7
    Moderator / KD6NIW TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear has a brilliant future. TundraBear's Avatar
    Join Date
    Mar 2001
    Location
    Just over there....
    Posts
    1,145
    Liked
    1 times
    Images
    12
    Rep Power
    108
    good call glenn. originally i was thinking along the lines of how officerbob ran his. i can't remember how he got outta the cab, but i think he popped in the bed from the front then ran it under the rail.
    any suggestions on securing the line under the bed? i was thinking of running one of those under the hood lights with the mercury or whatever. this way the light comes on whenever the lid is up and it goes off when it's closed. this way i wont have to worry about leaving it on. then i was thinking of adding an inline switch so i can leave the lid open all day long while enjoying the company of fellow TS'ers at a Jam or whatnot!
    2006 Tundra Limited DC: UniChip | Ram Air Performance System | TrueFlow Sealed Air Intake | 24" Bassani X-Muffler with Quick Time Electric Cutouts | IS Rims w/ Michelin LTX A/T2 | SkidRow FSP | Hellwig Antisway Bar | Retrax Bed Cover | Bazooka VSE | front/rear parking sensors | power tailgate lock | debadged | tinted
  9. #8
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,435
    Liked
    11 times
    Rep Power
    1671
    Check out "How to wire the lights in a camper shell to work under control of the cargo light switch." listed on the Miscellaneous Lighting page of the TundraSolutions.com Lighting & Electronics FAQ for an idea of how to do this.
    Note: Above referenced link is acessiable by club members only.
    ~Glenn
    Yes I am a pirate!
  10. #9
    Join Date
    Feb 2002
    Location
    Portland, Maine
    Posts
    53
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    I'm still looking into accomplishing this. I still haven't figured out anything concrete. Thanks for the Cabela lead, glenn233. They're close to what I'm envisioning. Unless modified, they require drilling into the bed for the ground connection. From poking around the lights section at pretty much any store that has one, I've realized that these Cabela Bedlighters are simply repackaged license plate lights. So anyone who goes this route can pick these up at RV stores, just under $9 a piece.
  11. #10
    Join Date
    May 2003
    Location
    Wausau, Wisc.
    Posts
    29
    Liked
    0 times
    Rep Power
    11
    This is a good topic. I'D BE DISAPPOINTED IF THIS IS MOVED TO THE "EXCLUSIVE, PAY FOR USE" area.
    This isn't rocket science folx. The hang up is the lights themselves & mounting. Wiring: Out the cab via the hood release, down next to the brake lines, along the frame, and then parrot's idea out the taillight to the bed.
    Frankie might have something with license lights. The lenses would have be a lexan material or something. They would have to take a moderate about of abuse, say from a ladder, bucket, shovel, paint cans, or even topsoil. I'm looking to mount mid-bed on the left and right sides right where the bed liner convexs outward- there's a nice hollow area that'd work nice.
    Have you thought of using an LED third brake light, under the front rail? It'd be red, but its just for low watt visibility.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
