well,.....
if you can use 3 or 5W luxeon bulbs...much better....
check
www.ledlight.com and
www.superbrightled.com ....
i looking at changing the front orange turn signal to a LED but it is a dual contact bulb and probaby have to change the Flasher Relay as well.... load resistors are OUT....
i got the rear taken care of by buying the LED setup from Longo...AWESOME LOOKING and super bright/instant ON !!!
the front HEAD LIGHT is changed to 6K xenon/relay setup and i just need to change the front turn signal bulb....
jim R
so calif
07 tundra 5.7
