First let me say that I am not proficient with 12 V electrical systems on automobiles.
Yesterday I proved it trying to install auxiliary backup lights on my Tundra. Here is the link I started for that project to get started
http://www.tundrasolutions.com/forum...eded-new-post/ at the end of that link I gave an update that said post hookup I do not have any back up lights on the vehicle or auxiliary system. All other systems seem to work including brakes, turn signals and hazard functions of the rear lights. FYI, I used the center pin for my trailer harness as my power source (Grey wire) and a bolt that holds the rear bumper on as my ground. I used the Grey so the auxiliary lights will only go on when the vehicle is in reverse.
Once it warms up a little I am going to start looking at fuses. I thought the vehicle and trailer fuses are two different systems, each having their own fuse. Where is the fuse panel on the drivers side interior? is it under the steering wheel or in the kick panel? If the fuses all check out as good where should I look next ground locations, polarity on the light hookup?
I AM AN IDIOT!
