Re: Off-road light install using Soltek harness
I actually made the grill from scratch. After many prototypes I finally was able to make one to the dimensions I wanted. By cutting out all the factor grill vents the bottom piece slat becomes really flimsy. To reinforce it I added a threaded bar which bolts through the side of the grill. You can see it in the last photo. Even with that bar that bottom slat would be to flimsy to bolt a light to. If you want I can sell the light mounts for $75 a pair with all the hardware and the grill for around $80 with out the toyota symbol in the center.
 2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
265x70-17 BFG's AT KOs
8" Soltek grill mounted race lights
HID upgrade on factory fogs
Custom grill
JVC KD-AVX1 w/reverse camera
10" JL Sub and 600watt Power Acoustik amp
"Freedom isn't free. It costs a buck O five."
