Old 03-16-2009, 07:36 PM
bajabanshee's Avatar
2005 Toyota Tundra
Last Online: 04-02-2009 08:30 PM
bajabanshee is on a distinguished road.
bajabanshee's Photo Albums
Default Off-road light install using Soltek harness
For those who have wanted to install off-road lights on their trucks but haven't, here is step by step install using Baja Designs Soltek wiring harness. This harness is extremely easy to install. Out of the box it’s setup to activate two auxiliary lights via your high beam switch and can be done in less than a hour. This makes it California compliant and also means you do not need to run any wiring through you fire wall. For those who did not know, you can legally run two auxiliary lights, with out covers, as long as they can only be activated by your high beam switch. Some cops do not know this so just in case you do get pulled over, here is the CA vehicle code and link to the dmv website. I wish I had this harness a few years back on my Tacoma when I was fined for having no covers.
24402. (a) Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height of not less than 16 inches nor more than 42 inches. Driving lamps are lamps designed for supplementing the upper beam from headlamps and may not be lighted with the lower beam. V.C. Section 24402 - Auxiliary Driving and Passing Lamps
The reason why the lights need to be wired via of your high beam switch is so you don’t have to fumble around your dash when you need to turn them off. IMHO it's so much better wiring your lights this way. It's easier to install and easier to turn them on/off with
If you do not want to wire them off the high beam switch there is a toggle switch option. It's a separate harness that plugs directly into the Soltek harness. When using the toggle switch harness remember that to be legal you will need to cover the lights when ever you are on the street. There is also a splitter harness if you would like to add an additional lights. Legally you can only run two lights.
To start here is a picture of the basic harness, switch kit and splitter harness.
First detach the ground cable(s) from the vehicle’s battery. From the Soltek harness attach the red fused ring terminal to the positive side of the battery. Attach the black ring terminal lead to the negative terminal or suitable grounding surface.
Now mount the relay to your firewall or inner fender. Make sure to mount it so that the wires are exiting the relay from the bottom. This will prevent water from getting into the relay and damaging it.
Next route the leads for the lights through the front radiator support. If you have Soltek lights simply plug the weather pac connectors from the harness into the lights. If you have other lights, I suggest cutting off your connectors and installing new weather pac connectors. Make sure to secure any excess wiring with zip ties. Be sure it can not be pinched, burned, crushed, or pulled too tight as this well lead to electrical failure.
To activate the lights you will need to determine in you will be using the optional toggle switch harness or the factory high beam wiring. If you are using the toggle switch you will need to find a suitable location on the dash for the toggle. Mount the switch and route the harness through the fire wall. If you look at the fire wall you can usually find a hole to push the harness through. Next plug the switch harness into the white three prong connector on the Soltek harness.
Now locate the short ring terminal extension provided with the switch kit.
This extension is used to ground the relay and insulate the exposed hot lead in the Soltek wiring harness when the vehicles’ high beam switch is not being used to trigger the lights. Attach the extension wires (yellow & black) to the yellow & black wire pair from the main Soltek harness. Attach the ring terminal from the extension to the chassis of the vehicle.
Now if you are doing it the legal way and using the high beam wiring to activate the lights you will need to attach the yellow and black wires to the wires plugging into your headlights. On a H4 or three prong bulb you will need to identify the positive high beam wire and the negative wire. Looking at the H4 connector from the front the positive high beam wire should be the terminal on the left. The center upper terminal is usually the positive low beam wire and the negative the terminal on the right. On a single filament bulb you will have only two wires. Again determine what wires are positive and negative. Crimp the included splice connectors onto the wires and plug the yellow wire from the Soltek harness into the positive high beam wire. Plug the black wire into the negative headlight wire.
Lastly reattach your ground cable(s) to your battery and test you lights. If you wired them correctly the lights should come on with the high beams or by flipping the toggle switch. If you wired them to your high beams and they do not come it’s possible you plugged the yellow and black wires into the wrong wires. If you reverse polarity to these wires it will burn the relay and pop your headlight fuse. I found out the hard way and popped about five fuses before checking the relay.
Note that the white connector on the harness will not be used if you are not using the optional toggle switch harness.
2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
265x70-17 BFG's AT KOs
8" Soltek grill mounted race lights
HID upgrade on factory fogs
Custom grill
JVC KD-AVX1 w/reverse camera
10" JL Sub and 600watt Power Acoustik amp
"Freedom isn't free. It costs a buck O five."
Old 03-16-2009, 10:17 PM
socalenduro's Avatar
Dealer : Kearny Mesa Toyota Scion
2006 Toyota Tundra Phantom Grey DC 4wd
Last Online: 07-02-2009 01:05 AM
Images: 15
socalenduro is on a distinguished road.
socalenduro's Photo Albums
Default Re: Off-road light install using Soltek harness
show us some pics of how you mounted your lights and how they look with your grill
06 DC 4wd
2.5" Front Lift via 5100 Bilstein's top notch
1" Diff Drop
17x9 Mojave Teflon
285/70/17 BFG AT KO
Snugtop Xtravision
Old 03-17-2009, 10:45 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Please resize your pics to no larger than 800x600 or the pics will be changed to URLs. Thanks!
Mike
http://dyogim.blogspot.com
Old 03-17-2009, 07:57 PM
2005 Toyota Tundra
Here are a couple pics of the lights mounted to the radiator support. It's a tight fit but I got them in there.
2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
Custom grill
Old 03-18-2009, 02:52 PM
Images: 15
Those look great. Total custom job?
What mods did you do to the grill so that they show thru?
06 DC 4wd
1" Diff Drop
17x9 Mojave Teflon
285/70/17 BFG AT KO
Snugtop Xtravision
Old 03-18-2009, 10:40 PM
mestizo223's Avatar
Dealer : Power Toyota Cerritos
2005 Toyota Tundra
Last Online: Today 01:16 AM
Images: 64
mestizo223 is on a distinguished road.
mestizo223's Photo Albums
could you post some pics of the hood down and the grill?? and did you fab up the mounting bracket or purchase it somewhere
Old 03-19-2009, 10:44 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
x3 for a pic of the grill down. I've been thinking about mounting my lights on the grill or through the grill. Nice custom job!!!
Mike
Old 03-20-2009, 01:22 AM
2005 Toyota Tundra
I will try and post some pictures tomorrow of my grill.
2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
Custom grill
Old 03-23-2009, 01:36 PM
Images: 15
pics pics pics.....
06 DC 4wd
1" Diff Drop
17x9 Mojave Teflon
285/70/17 BFG AT KO
Snugtop Xtravision
Old 03-24-2009, 04:04 AM
mestizo223's Avatar
2005 Toyota Tundra
Images: 64
i second that!!! please!!! i think he is teasing us!!!
Old 03-24-2009, 04:26 PM
2005 Toyota Tundra
Ok, I finally got time to take some pictures. Let me know if you want more.
2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
Custom grill
Old 03-24-2009, 05:20 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Is any of the light output diminshed from the grill? Thanks!
Mike
Old 03-24-2009, 08:08 PM
Images: 15
so did you make that grill yourself?
what about the light mounts? purchased or selfmade?
killer!
06 DC 4wd
1" Diff Drop
17x9 Mojave Teflon
285/70/17 BFG AT KO
Snugtop Xtravision
Old 03-25-2009, 01:28 AM
2005 Toyota Tundra
By my eyes I would say the grill diminishes the light by like 10-15%. It's still really bright though. I did make the grill and light mounts. If you guys are interested I might make some to sell.
2006 Double Cab 2x2
Bilstein Coilovers
17" Helo Maxx
Custom grill
Old 03-25-2009, 11:04 AM
Images: 15
id say there would be plenty of interest. How much were you thinking?
06 DC 4wd
1" Diff Drop
17x9 Mojave Teflon
285/70/17 BFG AT KO
Snugtop Xtravision
