Old 03-18-2009, 09:44 PM
Last Online: 03-18-2009 09:45 PM
red snapper is on a distinguished road.
red snapper's Photo Albums
Default Headlights staying on.
Hello everyone, this is my first post. I stumbled upon this site because Im having problems with my 05 Tundra.
I bought this usa truck from a dealership in Vancouver,BC in Nov./08.
Since I have had this truck its been to the dealership 14 times! The problem is the headlights are going on themselves. In the mornings when I get up to go to work, I am greeted with a dead battery. Sometimes after driving the lights will stay on and the power door locks will stop working.
When I bought this truck, I bought the extended warrant thinking just in case something happens.
The dealership has always givin me a courtesy car and has been really good. But they have no clue as to what the problem is and want to buy the car back from me.
I really love this truck, and would just like to see the problem fixed. If anyone has any suggestions, It would be appreciated.
Thanks,Brian.
Old 03-19-2009, 01:28 AM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Today 01:26 AM
Images: 49
hofkamp83 will become famous soon enough.
hofkamp83's Photo Albums
Default Re: Headlights staying on.
my guess would be that you have a short somewhere on truck where maybe a wire got pinched maybe within the door lock wiring since that stops working at times, just a guess though. if that is the case it will be a real pain to find unless you get lucky. my dads envoy had about the same problem and found a pinched wire within the trailer harness fixed it an no more dead battery's. good luck.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Old 03-27-2009, 05:17 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 11-16-2009 09:59 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
Thanks,Brian.
If you like the truck, I would tell them to keep trying until it is fixed. They will most likely have to replace a wiring harness to solve the problem. Another alternative would be to have them find you a truck with similar or better features and the same or lower miles and an even trade.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Old 04-14-2009, 08:58 AM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Yesterday 11:29 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
If they haven't replaced the light switch by now, you may want to try someone who knows what they are doing. The harness is the next culprit. I'd open every connector and clean the contacts.
Old 04-14-2009, 08:30 PM
masterofstuff's Avatar
Dealer : Tri County Toyota
2004 Toyota Tundra Double Cab
Last Online: 10-15-2009 11:57 PM
masterofstuff will become famous soon enough.
masterofstuff's Photo Albums
I'd disconnect the DRL and see if that helps. Its the connector behind the battery, it's really down in there so you'll have to move the battery.
Old 11-17-2009, 01:12 PM
Last Online: 11-17-2009 01:12 PM
Halatosis is on a distinguished road.
Halatosis's Photo Albums
06 tundra with same issue. Headlights come on without switch being on and no provocation by keyless lock. May happen once a day or every half hour. disconnect of battery only solution at this time. Dealer states never heard of problem, refer him to this web site.
Old 11-17-2009, 04:28 PM
2005 Toyota Tundra
Last Online: Today 02:19 AM
cheapskate is on a distinguished road.
cheapskate's Photo Albums
Also have US truck with same problem. Dealer installed aftermarket relay for DRL's and did not go through stock wiring. They replaced the relay and no problems since. Not sure if your DRL's are stock or external relay but hope that helps.
AFE CAI, Magnaflow Catback15820, Line X bedliner. Really nice air freshener-not the pine tree one.
