Old 03-20-2009, 05:19 PM
Dealer : Toyota Scion of Melbourne
Last Online: 09-25-2009 02:24 PM
Whitey436 is on a distinguished road.
Whitey436's Photo Albums
Default 2000 Tundra Horn Problem
I have a horn that works intermittently and I have no idea what might be causing it. I took the steering column apart according to a Haynes manual and cleaned the contacts that are involved with the horn. It worked great but unfortunately it was during the time that the horn seemed to be working well, which does occur.
It has nothing to do with wet versus dry conditions, e.g. rain etc. Today as a matter of discussion.. it was working then I tried it 10 minutes later with no luck. We were driving on a trip 75 miles each way and it never worked again during the trip at all.
I have not been able to coorelate when it does or doesnt work to any certain condition because it literallly can work and then not work within the span of minutes. There are two horns under the hood as a stock design so I do not believe it is either of those.
Any ideas would be most appreciated.
Thanks,
Keith
Old 03-20-2009, 05:24 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Default Re: 2000 Tundra Horn Problem
Have you inspected the horns themselves under the hood.They could be going bad or a loose connection. They are located at top of the radiator support. Try swapping them out with some Hella's (deep or high tone or 1 of each).
Mike
http://dyogim.blogspot.com
Old 03-20-2009, 05:32 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 12:08 PM
Images: 578
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Are both of the horns having problems or just one? Both horns are on the same circuit so if both are dropping out, it could be the horn switch in your steering wheel, the horn relay, or the wiring. If only one horn drops out, it would probably the horn itself or a loose connection to that individual horn.
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 03-20-2009, 08:46 PM
08SalsaMax's Avatar
Last Online: Yesterday 07:28 PM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Chech your grounds as well....
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
Old 03-21-2009, 08:00 AM
I found a common element that Im pretty sure is the source of the problem. Its the remote access/security system. The system causes the horn to chirp when arming/disarming. When the horn isnt working via the steering column if I hit the remote access it chirps as it should everytime, then the horn will work for some time.
The issue is whether this can be 'fixed' without having to replace the remote system. However not having a functional horn is a bigger issue.
Any advice would be appreciated.
Old 03-22-2009, 11:30 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 11-16-2009 09:59 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
Thanks,
Keith
IF the wiring for your year model is the same as my 03, the wire going from the horn switch to the integration relay is green with a red stripe and goes to pin 12 of the integration relay (located with the interior fuse panel). If you can get to that wire, you can see if the signal is grounded each time you push the horn switch.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
