Old 04-22-2009, 10:34 PM
Last Online: 10-20-2009 03:01 AM
handirifle is on a distinguished road.
handirifle's Photo Albums
Default Lighting question
I have an '06 DC . There are a lot of roads here in SoCal that require daytime headlights. The problem is, when I turn them on, in daylight, the interior lights become too dim to read.
Can I bypass this somehow?
Can I install a separate headlight ONLY switch that will still go off in case I forget and leave it on?
I've seen threads of DRL's but mine did not come with them and they cannot be added, I've been told.
Old 04-24-2009, 08:20 AM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Today 01:13 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
Default Re: Lighting question
What about adding switched fog or marker lights? This may be the simplest mod. You could get a gen2 Tundra DRL relay, and wire that into the turn signals lights as the gen2 uses. I have seen in threads where people have removed their relay so you might get one cheap
