Old 05-18-2009, 08:27 PM
Last Online: 11-20-2009 05:13 PM
Velocibiker is on a distinguished road.
Velocibiker's Photo Albums
Default Is there a way to disable dash dimming when lights turned on?
I have a (new to me) '08 Tundra. Not sure yet what all the correct acronyms are, so I'll just spell it out
Double Cab. 'Tundra Grade'. No JBL.
Ok, here's what I want to do;
I basically drive with my headlights (or parking lights) on all the time - kinda like when I ride my motorcycle. However, what I DON'T like is the fact that turning on my headlights causes the instrument cluster guages to dim out. I can't even read the time or temp.
So, if anybody knows what wire to snip so that this no longer happens, I'd appreciate it.
Old 05-18-2009, 10:44 PM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Today 09:54 AM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
Default Re: Is there a way to disable dash dimming when lights turned on?
Why not get the drl relay, it turns on the running lights only but doesn't dim your dash
Old 05-19-2009, 06:00 PM
1. Cause I didn't know there was one
2. Cause I'm cheap-skate and would rather fix the issue for nothin'
3. I don't have any "running lights". There's just plastic blanks where (I assume) fog/running lights would go.
Thanks tho.
Old 05-19-2009, 10:54 PM
SE2000's Avatar
- Other -,
running light are those lights next to your low/high beams.
And the cheapskate special is to advertise to switch with someone who has them and doesn't want them
Old 05-21-2009, 05:37 PM
No worries. Turns out I found a solution!
Helps to read the OM. According to the OM, if you turn the dash light brightness all the way up, when parking or headlights are switched on, nothing dims.
Tried it and it works.
Old 05-25-2009, 07:37 AM
tun dra's Avatar
Dealer : Moose Jaw Toyota
Last Online: 11-22-2009 11:44 AM
tun dra is on a distinguished road.
tun dra's Photo Albums
Hey that good to know. Thanks
