Old 05-23-2009, 03:20 PM
Dealer : Le Mieux & Son Toyota
Last Online: 11-18-2009 10:56 PM
greybeards22 is on a distinguished road.
greybeards22's Photo Albums
Default back up lights
Who makes the best lights for this? I installed a cheap set a year ago and they rusted out. thanks
Old 05-23-2009, 03:55 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Default Re: back up lights
I got fed up with the anemic quality of the stock reverse lights - especially with how often I am backing a trailer on my service drive at night or hitching before the sun is up. I wired these independently of the reverse so I can flip them on to hitch while in park or warn aggressive tailgaters on the highway.
Help with Auxilary Back up Lights
Total cost was less then $50 as I had to buy additional wiring to make the run from the battery and dashboard back to the lights on my hitch frame. Not sure how long they will last but I love them and if they burn out I can get another set from Autozone for around $35. I bought my BAJA lights several years ago for around $20 but they have since gone up in price. They make backing out of parking spaces at night a lot safer as cars that would otherwise force their way past me now give me ample time and room to get out of my parking space. Backing the trailer up the service drive at night is so much easier when I am not doing it by feel and can actually see where the damn thing is back there in relation to the trees and the ravine.
There are a ton of different ways to go about putting in auxiliary back up lights on your truck - this was cheap as I already had the lights from a former project. I hope this helps you to get some ideas for your application.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 05-23-2009, 05:43 PM
Last Online: Today 10:31 AM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
My pair of PIAA back-up lights have served me well. The switch allows you to have them come on automatically when you go into reverse, or you can actively engage the ligts. They're more expensive than Wally World fog lights that you could also use.
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
Old 05-23-2009, 11:38 PM
Images: 64
Nice looking install - how did you attach them? I fabricated brackets and welded them to the hitch frame. How does it look backing up at night?
back up lights-baja-lights-from-rear-corner-bed.jpg   back up lights-baja-lights-window-down.jpg   back up lights-truck-reverse-lights-window-down.jpg   back up lights-truck-reverse-lights-window-up.jpg
Old 05-24-2009, 10:17 PM
Images: 43
They have 180 degree light dispersion, so the sides light up really good back there. Since the lights mount with double-sided tape and/or self-taping screws, I had to find a relatively level place to mount the lights. Where you see them mounted is the most level place I could find back there - as it turns, out it was OK. I would have prefered a bit more closer to the outside edge. I have the back-up camera, so I can see pretty good without the lighting, but it really helps with the sides as well as telling folks behind me that I'm coming their way.
