Old 06-18-2009, 12:50 PM
larycut's Avatar
Dealer : Toyota of Riverside
2004 Toyota Tundra
Last Online: 11-14-2009 03:46 AM
larycut is on a distinguished road.
larycut's Photo Albums
Default Battery Drain
My sister has a 2004 Limited DC she is having battery drain over night, she has had the amp parasitic drain corrected, changed battery still no change. Could it be the starter because it clicks if it was a drained battery it would do nothing.
Thanks Larry
2004 Tundra AC Limited
Added to date Bilstein 6024, 6025, FMS Sports Grille. De-Badged, Kenwood KSC-SW1 Subwoofer in storage compartment rear passenger side, Infinity 6012i & 6012si 6”sub in doors, Kenwood DNX 7100 w/XM, Turboliner bedliner, J & J Chrome Running Boards, chromed factory rims, K&N cold air intake, Window tinting. Viper Alarm and Viper GPS systems, Personal Identity security system,SilverStar 9003st headlight, 05 tail light, clear corner lens with 3157ast Silverstar, DynoMax exhaust
,Muth Signal Mirrors, SnugTop Snuglid SL hard tonneau.
Old 08-02-2009, 12:30 AM
velocitymotorsports's Avatar
Last Online: 10-11-2009 12:32 AM
Images: 9
velocitymotorsports is on a distinguished road.
velocitymotorsports's Photo Albums
Default Re: Battery Drain
For parasitic draws you have to find out where the draw is coming from. Do you have a multi meter ? Do you know how yo use it ?
Pull the ground from the battery, make sure all doors and anything that can draw power is off(so you don't blow the meter's fuse, so no domelights and no ign), set meter to mA, place meter in line with - terminal and the battery, walk away for 30 minutes, come back and get the reading. If the measurement is more then 50mA then something is drawing current. But even at this low a draw it would still take more then 2 or 3 days on a GOOD battery. If you do have a draw start pulling fuses to eliminate different circuits. When the draw goes away you've found the circuit that is causing problems.
Jeff Sit, Owner & Installer
Velocity Custom Home Theater
Mobile Audio/Video Specialist
Morden, Manitoba
http://www.velocitymotorsport.com
Suspension, wheels, tires, accessories & more
Old 08-02-2009, 01:50 AM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 09:09 PM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
As a first guess I would look at the alternator as a possible parasitic load.
Attention environmentalists, reduce emissions from this:
Old 08-10-2009, 06:47 AM
masterofstuff's Avatar
Dealer : Tri County Toyota
2004 Toyota Tundra Double Cab
Last Online: 10-15-2009 11:57 PM
masterofstuff will become famous soon enough.
masterofstuff's Photo Albums
I had the same issue with my 04 dc. I had the original wet cell battery about 4 years when it suddenly started to die. I'd get up to go to work and find the battery dead.
I replaced the battery with a optima and no more problems. A couple of cells died in the wet cell...it does get real cold in Pennsylvania at times.
Old 08-10-2009, 11:20 AM
Last Online: 08-11-2009 01:25 PM
pimpmassa is on a distinguished road.
pimpmassa's Photo Albums
This just happened to me this weekend in my 04 dc. I just assumed i left a door ajar and drove the truck around for about an hour to charge it up. After arriving at home, it started right back up, then this morning it wouldn't turn over.
I have not yet tried to see if there was a parasitic load, though i wonder if my extended warranty (that i unfortunately got talked into buying) will cover a new battery? I think i will buy a new one anyhow. Is there a particular model of optima that everyone is using for their DCs?
Old 08-18-2009, 08:25 PM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC,
- Other - 2007 Suzuki Burgman
Last Online: 11-03-2009 07:50 PM
Images: 2
benbeaux is on a distinguished road.
benbeaux's Photo Albums
Clean the top of the battery. Dirt/oil/grease/crud can cause a battery to drain by creating a high resistance across the terminals. High resistance=low current (Ohm's law).
Also, make sure the terminals are clean & tight. A loose terminal can prevent the battery from fully charging.
