Atention Mod Squad.....................
Wiring Help!!!!!!
Im trying to wire in some leds under the dash, seats and behind flip seat mod on 2008 DC. I would like the new ones to react the same way the stock over head map lights do. On with the doors, off with the key, fade, then on with dash switch etc. Ive read a ton and only have been able to find stuff that uses just an on off switch. Is there an easy way to tap into the circuit that controls the over head maps to run the new ones. Would i need fresh
power and a relay? im just putting in 6leds with 4 or 6 bulbs on each strip from v-leds. Any Ideas would be great.
thanks
Slate
