Battery Wiring Mistake!
I have a 2006 Toyota Tundra V6. My dad accidentally wired the positive cable to the negative battery terminal and the negative cable to the positive battery terminal! Some fuses were blown and I replaced those. However, my headlights, blinkers, radio, air conditioner, and the alternator still won't function. Any help would be appreciated. Thanks.
Update:
I found the 120A fuse was also blown. It was a hassle to remove it as it required taking the fuse compartment apart. However, once the new 120A fuse was installed, everything returned to normal. There is no longer any issue.
Reason: I fixed my problem...
