Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Free Shipping at Buy.com!
FREE Personal Trainer Program
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "ignition switch", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-17-2003, 03:32 AM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
jim65wagon's Photo Albums
Last Online: 08-25-2008 07:39 PM
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon
Default ignition switch
On Wednesday I got in my truck at 4:30 to go to work as usual. Put the key in the ignition and it wouldn't turn...tried all three keys, none turned. Wiggled the gear shift lever....key wouldn't turn. Wiggled the steering wheel....key wouldn't turn. Went to work in wife's car, she called later in the morning said she started the truck, it turned harder than usual but turned and now it seems fine. What gives?
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380C on board air; Daystar 1.5" lift; Deaver 3leaf AAL
Old 07-19-2003, 12:09 PM
Dealer : Earnhardt Toyota
AZ TUNDRA's Photo Albums
Last Online: 07-19-2007 10:56 PM
AZ TUNDRA is on a distinguished road.
You probably had tension on the wheels. Instead of wiggling the steering wheel, apply strong pressure in on direction and attempt to turn key. If that does not work try the opposite direction. Remember to maintain the continuous pressure. You have to turn the wheels without the benefit of power steering. Hope this works for you.
Old 07-20-2003, 07:40 PM
jim65wagon's Avatar
Thanks, if it happens again I will try that.
Old 07-21-2003, 11:46 PM
S-Man's Avatar
2002 Toyota Tundra
S-Man's Photo Albums
Last Online: 05-15-2008 09:19 PM
S-Man is on a distinguished road.
my truck does that sometimes too...it almost makes me panic every time. heeheh. but i eventually keep yankin' the wheel back and forth, and realy apply some torque to that ignition-key, and it eventually turns, but with much effort. And it is because the wheels are in a bind.
Old 07-23-2003, 12:17 PM
Dealer : Elk Grove Toyota Scion
marlinmaster's Photo Albums
Last Online: 04-21-2007 06:18 PM
marlinmaster is on a distinguished road.
Strange a co-worker asked me if I was having this type of problem with my Tundra. He has a 2001 Sienna and this problem started a couple weeks ago. He took it to a shop and they said have another key made and see if the problem is corrected. If not they will replace the cylinder at the cost of 150 or so. He took the key to a locksmith and he said the problem is with Toyota cylinder. It is keyed for 10 but the only use 8. The remaining 2 get loose and or slip. This is what causes the problem. For 45$ the locksmith said he would pull the cylinder and rekey it to 8. I'm not sure if the Tundra uses 8 10 or whatever but it sure sounds strange.
Old 07-23-2003, 10:30 PM
S-Man's Avatar
2002 Toyota Tundra
how about that. that could be the problem too... hmm...somthing to look into.
Old 01-04-2005, 07:00 PM
CATiger's Avatar
Dealer : Dublin Toyota Scion
CATiger's Photo Albums
Last Online: 06-18-2008 07:14 PM
CATiger is on a distinguished road.
Send a message via AIM to CATiger
Default time to ressurect an old thread
Dropped my tundra off at the dealer for a timing belt change and some regular maintenance. He called back to ask if I'd ever had a problem with the key or cylinder. I said, "nope not in 4 years." Well I stopped by to drop off an original key, and try it out. Still no luck... The thing is jammed solid.
Oh and now a whole day is wasted, they couldn't even move it to get it on the rack for service! Luckily they gave me a loaner at no charge...
- JD
2000 Toyota Tundra Limited 4x4 w/ TRD Package
Thunder Grey Metallic
Factory Options: Leather Captain's Chairs, Color Keyed Running Boards, tow package
Aftermarket Additions: JVC KDSHX900 w/ HD, Sirius S50 Satellite Radio, JL Audio Stealthbox, Eclipse 500W 5-channel Amp, MB Quart Ref Components w/ 1.5" tweeters up front, Coax rears, Peel & Seal sound deadening, Trenz Billet Grill, Tailgate Extender, Sylvania Silverstar headlights, Hella SuperTone Twin Horns, Ivan Stewart Body kit sprayed with Duplicolor bedliner
Modifications: JBA Titanium coated headers, Hellwig Anti-Sway Bar, TRD Dual Side Exit Exhaust, TRD IS Wheels Polished and Powdercoated Gunmetal Grey, shod w/ 285/75R16 Bridgestone Dueler A/T REVO, RaceRunner Sway-A-Way Coilovers & Daystar Add-A-Leafs, Front Porterfield Brake Pads, Power Outlet Mod, Rear Seat Mod, NGK iridium plugs
Latest modifications: Sirius S50 Satellite Radio, Unichip, Powertrax No-Slip Rear, grey bumpers, G tech
MySpace
Old 01-05-2005, 06:52 AM
jim65wagon's Avatar
mine still locks on occasion, but all it takes is a slight turn of the wheel and the switch frees right up and turns. No yanking hard on the wheel just a small turn.
Old 01-06-2005, 05:00 PM
CATiger's Avatar
Default great
The dealer installed a new cyliner and ignition switch in my column. Cool. BUT they keyed it to a different key than my doors/tailgate/gas. UG. Now I have to go back and get it done right. Sheesh kind of a bummer. Oh well. They are going to give me a couple free keys. Yippee.
- JD
MySpace
Old 08-11-2006, 08:43 PM
Tundradouger's Photo Albums
Last Online: 08-11-2006 08:43 PM
Tundradouger is on a distinguished road.
Default Re: ignition switch
My key is jammed solid. Won't turn. I am parked on a slanted hill driveway. I tried for a long time and cannot get it to turn. What a drag. I will try moving the steering wheel harder this time. I tried three different spare keys and still won't turn. Wish me luck. Someone told me to tear it a part and start it with a screw driver. I am afraid to do this.
Old 11-24-2006, 03:33 PM
Dealer : Anderson Toyota
cbb852's Photo Albums
Last Online: 12-04-2006 03:57 PM
cbb852 is on a distinguished road.
Hi,
Is it that difficult to replace the ignition cylinder? My key "lock up" was caused by everything but the kitchen sink on my key ring. So, I either need to get a new ig. cyl - lowest quote was $103 or get the ignition out and get it re-keyed. If I can do the latter, then I'd like the locksmith to configure it to an "8" like in one of the previous posts.
Does a part store have a book that has how to remove the cylinder? I don't care if I have one key to open the door and another to start the car.
Thanks,
Cathy
Old 11-25-2006, 09:12 PM
Dealer : Panama City Toyota Scion
gsxrsquid's Photo Albums
Last Online: 08-26-2008 07:03 AM
gsxrsquid is on a distinguished road.
hanging lots of junk on a key ring will cause premature wear in an ignition lock. USUALLY though the problem is caused by pressure of the steering wheel lock bar on the cylinder. If you turn the wheel enough to release the pressure the lock should turn. Also if you are in a habit of parking in such a manner as to cause this to happen often it will also prematurely wear the cylinder.
Old 12-09-2006, 11:21 AM
2003 Toyota Tundra
lost_in_california's Photo Albums
Last Online: 02-03-2007 10:02 AM
lost_in_california is on a distinguished road.
I had to call AAA last night to come out and try to turn my key. Carmichael Towing guy said it is definitely a Toyota problem, the last plate in the ignition gets loose and prevents the key from turning. He got it turned, then took a tool and banged on the end of the key to push the plate back down temporarily and recomemmded getting the ignition replaced. Which locksmith quoted you that price? I would like to call him as well, since replacing the whole cyclinder is a lot more expensive.
Old 12-09-2006, 11:25 PM
Dealer : Jones Toyota
abr10dr's Photo Albums
Last Online: 07-19-2007 11:33 AM
abr10dr is on a distinguished road.
Had the same problem tonight, 400 miles on the truck, my wife turned the key over and that worked, anyone have the same experiance?
2006 Tundra Limited DC 4WD
Salsa Red Pearl
Mods so Far:
Custom Grill from TRDparts 4U
DiamondBack SE Bed Cover
EGR in channel Window Visors
TRD Air Filter
Debadge
SoundLinQ SLI with 30G iPod
VSE Subwoofer by Bazooka
Next:
Hellwig anti -sway bar
Nerf Bars
Cat back dual exhaust
Old 03-04-2007, 10:25 AM
mostsleek's Avatar
Dealer : Lipton Toyota Scion
2000 Toyota Tundra,
- Other - 2003 Mazda MX5
mostsleek's Photo Albums
Last Online: Yesterday 09:38 PM
mostsleek is on a distinguished road.
Send a message via AIM to mostsleek
I have the opposite problem, mabey a sign of things to come. I can tun my truck on fine, but sometimes go to turn it off and pull the key out it gets stuck. Not that bad, but bad enough that my fingers slip off. It might be that I am in a hurry and it has yet to spin to the off position. After reading this post, it gets me kinda worried .
2000 Tundra Access Cab
Survived 4 tropical storms and 5 hurricanes
Survived a baseball sized hail storm
Hosted numerous tailgate parties
Water balloon refilling depot
Served as a portable pool
FLORIDA MEET PICTURES
