Old 09-22-2009, 08:12 PM
Last Online: 10-31-2009 06:09 PM
dezthumper is on a distinguished road.
dezthumper's Photo Albums
Default DIY LED Resistor INSTALLATION brake lights
Please find the attached link to a complete pdf of how to do it yourself. I took seemingly endless threads and pages as well as great pics from other board members - SNOOP had the most pictures.
I am ready to start doing some of these wonderful modifications that will compliment the truck and instead of taking hours while doing the work, I prefer a simply print and use pdf with step by step, monkey-proof pictures to aid in my project.
I am brand new to Tundra and this forum and thought that before I "take" that I would first "contribute" and will continue to do so, when time permits. I am currently working on an V-LED fitment and recommendation list for both the Double Cab and Crew Max.
Anyways, enjoy.
Search words for forum search aid: rear, brake, brakes, light, lights, led, v led, v-led, resistor, 3ohm, 3, ohm, 6ohm, 6, replace, install, leds, hyper, hyperblinker, blinker, fast, rapid, hot, heat, sink, solder, pig, tail, pigtail, incandescent, bulb, bulbs, install, installation, do, it, yourself, diy, pictures, picture
Old 09-22-2009, 09:48 PM
Last Online: Today 06:07 PM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Default Re: DIY LED Resistor INSTALLATION brake lights
Great detailed write-up. When I installed mine, I noticed that the resistor gets REALLY HOT, just like the warnings, but more than I thought they would. I mounted my resistor horizontally, vice vertically and wire tied the the leads together to prevent the leads from touching the resistor. Finally, to add some circulation, I put small washers between the resistors and the truck surface. I was afraid the heat would melt melt the plastic and cause a short.... I'm probably too woried about those kinds of things. Check my album for a pic of my install.... I didn't want to hijack your thread anymore than I've already done so I didn't post a pic here......
Finally, I sealed up the front and back of the hole with some clear RTV sealant to reduce rust issues.....
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
