Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
I installed them on my truck.
1. Install the lights in the bumper and connect the wires. They plug right in. You'll have to remove the plastic inserts. If you don't have the nuts to mount the lights, you should be able to get them from a dealer.
2. Install the relay. It goes in the "fuse box" under the hood behind the battery. On the inside of the cover there is a diagram showing all of the fuses and relays. The relay for the fog lights is marked "fog". It goes on the row towards the rear of the truck, second slot starting from the drivers side. Just push it in.
3. Install the switch. It goes in the dash to the left of the steering wheel. It should go in the hole closest to the door. If I remember right, you just have to pry that small section of the dash off to get to where the switch goes. You should be able to figure it out. The wires with the plug on the end are already there, just plug it in, mount the switch, put the section of dash back on and YOU'RE DONE!
The fog lights will only come on when the head lights are on and on low beam.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
how I wired a 2002 fog light switch in a 2003 Tundra
Originally Posted by nhparrot
Difference would be in the switch. The '03 has the foglight switch on the stalk as opposed to in the dash.
I choose not to install a 2003 fog light switch in the light switch stalk because it looked too difficult. So I bought a 2002 switch and installed it into the cutout to the left of the steering wheel.
Here's how I wired a 2002 fog light switch in a 2003 Tundra without daytime running lights
