Old 03-28-2002, 10:35 AM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Default Whats it for?
Below is a picture that Iron Horse Herb took. I have "borrowed" a copy of it to ask you all a question. In this photo just to the left of the emergency brake pedal there is a white colored connector. It is mounted on top of the grey large plug seen toward the bottom of the picture. It has 3 wires going to it. I seem to remember from looking at mine that one wire (white/black stripe) is a fairly large gauge, maybe 14. This wire is hot all the time. I believe the other 2 wires going to it are a smaller gauge, maybe 16/18 and are also (white/black stripe). Can one of you guys with the "elec manual" tell me what this plug is for? This wire would appear to be an excellent power source for tieing into for an accessory. But I am wondering what it is tied to and what kind of load it will carry before I mess with it to much. Thanks.
picture link: "IHH" connector picture
SATundra
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 03-28-2002, 02:14 PM
SATundra's Avatar
Just moving it back up.
SATundra
MODS:
TIRES:
SUSPENSION:
Old 03-30-2002, 09:24 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:22 PM
nhparrot's Photo Albums
Sure, it's hot all the time? Looks like it might be a ground point.
~Glenn
Old 03-30-2002, 11:08 AM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
~Glenn
Same here. Looking at the photo,if you trace the wires from the plug it terminates to the plug that's bolted down to the sheetmetal,above the oval openning.
Old 03-31-2002, 08:16 PM
SATundra's Avatar
Default I checked
Well you guys had me curious so I just went out and looked AND TESTED mine. Inside the white 3 wire plug there are 3 flat wire prongs. The one on the left is HOT all the time. I am wondering what option or accessory this plug is for.
In the picture it "looks" like the 3 wires go to the other plug mounted on the cab wall above the oval hole, but in fact they don't.
SATundra
SATundra
MODS:
TIRES:
SUSPENSION:
Old 04-03-2002, 12:11 AM
IZL's Avatar
IZL IZL is offline
Dealer : Motor Imports
Last Online: 10-10-2009 01:07 PM
IZL is on a distinguished road.
IZL's Photo Albums
Default Short Pin S8
It is identified as S8 (Short Pin) and is for the main +12V for the Power Seats. It hot all the time and is protected by the 30A fuse in the Integration Relay by the driver's left knee.
Seems like the pins on either side (1 and 3) should be +12V. The middle pin (#2) is ground.
Old 04-03-2002, 11:33 AM
SATundra's Avatar
Default Re: Short Pin S8
IZL "Thank You", I knew I wasn't going crazy over here.
This would appear to be a good spot to obtain a constant +12v power source from inside the cab if it were not wired through the integration relay system. Still it might be an option for some.
Thanks again for your help.
SATundra
SATundra
MODS:
TIRES:
SUSPENSION:
