*** Copied from Previous Board - nhparrot ****
Topic: HID auxiliary lowbeam photos
Joey
TS Supporter
Member # 163
Member Rated:
posted 03-13-2002 11:20 PM
Hey, I liked your Idea soo much I had to go out and buy a kit for myself. I picked it up today, I am taking pics of the box right now. I'll post some tomorrow. I ended up getting the SENKO kit. The cost is a little higher than $350 though. What was the name brand of your kit ? Thanks.
Posts: 55 | From: La Palma | Registered: Feb 2002 | IP: Logged
Joey
TS Supporter
Member # 163
Member Rated:
posted 03-10-2002 11:02 PM
quote:
Originally posted by aika:
tundrabear- i too have the superplasmas in my truck (made by piaa no?). the fog lights bugged the heck out of me so i decided to switch them out. lo and behold- piaa doesnt make the 9006 superplasmas, only the h4...so i went with the nokya blue lamps. the color is not the same, but its fairly close. the fogs definitely have more of a blue appearance to them than the piaa's. if you want a color closer to the piaa's you may want to check out the purplish fog lights from nokya- they may be a litle bit closer to the superplasmas, since i think the superplasmas have a hint of purple to them. may help you out a little bit. i searched for the superplasma 9006- no luck...
PIAA does make 9006 Super Plasma. They are made in Japan for Japan. PIAA USA guys like me cant get their hands on them. HIPER bulbs are the same as the Nokyas. you can get HIPER for a better price. E-mail me if you want more info.
iforceV8
TS Supporter
Member # 1174
Member Rated:
posted 03-09-2002 04:29 PM
I believe the run time is 4hrs. I want HID again, but im buying camera equipment right now to start my busniess. So until I finish with that, my tundra will remain the same.
Posts: 27 | From: SoCal | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Platinum TS Supporter
Member # 3
posted 03-09-2002 01:31 PM
quote:
Originally posted by iforceV8:
So Ed, would you be the first one to do 2 HID kits on the Tundra? The 9006 HID kit looks really good. I might have to get a set or two again.
Yeah,I guess I am,but you were the first one to go HID in a Tundra to my knowledge. I recently sold my bi-xenon system for the same amount I paid for them,even with the high-beam feature not working.But I've ordered a new identical system and should have them in about 2 weeks,photos will be taken once they're installed.
By the way,that's one bad@ss flashlight! How long do the batteries last in that thing? Hmm,if a cigarette lighter adapter was available I might be tempted to buy one
Become a TS Supporter by clicking this link
Then check out my corny Tundra website @
http://home.att.net/~jadesr5/index.htm
Posts: 67 | From: New Jersey | Registered: Feb 2002 | IP: Logged
iforceV8
TS Supporter
Member # 1174
Member Rated:
posted 03-09-2002 10:02 AM
HID in the car is cool, but I also like my HID hand held.
http://www.brightguy.com/detail_int....2&sku=UND44601
iforceV8
TS Supporter
Member # 1174
Member Rated:
posted 03-09-2002 10:00 AM
TundraBear
Member # 132
Member Rated:
posted 02-24-2002 12:38 AM
thanks for the insight Ed JadeSR5 Tundra & aika!
I bought some sylvania 9006CB but i think they are really just whiter than the OEM. unfortunately they don't really match the headlamps. oh well. another step in the direction of getting there!
Get your TS Biz Card today!
a TS windsheild sticker????
although they will deny it...."THE BIG THREE" really means: "THE TOYOTA TUNDRA"
Posts: 85 | From: Los Angeles, CA | Registered: Feb 2002 | IP: Logged
aika
TS Supporter
Member # 87
Member Rated:
posted 02-22-2002 11:34 PM
Posts: 154 | From: San Diego, CA | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Member # 3
posted 02-22-2002 05:09 PM
quote:
Originally posted by Hover:
About how much did it cost you to make your foglights into HID?
$350 from an
ebay auction,if you do a little searching on the 'net you may find a better deal.
Pricey compared to tinted or higher-wattage halogens,but HID burners have output equivalent to a 100+ watt halogen but with the heat output of a 35-watt bulb. Also the type of light produced by HIDs increases visibility of anything reflective like road signs and lane markers.
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 02-22-2002 08:02 AM
thos are NICE! next mod for me
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
Hover
Member # 110
Member Rated:
posted 02-22-2002 03:54 AM
[ My Tundra | Tundra Picture Archive (1,600+ pictures) ]
Posts: 280 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Member # 3
posted 02-21-2002 10:29 PM
quote:
The foglights alone with HID look like they could be used as low-beams.
The pics on the roadside that you took from
hood level show the true amount of light
distribution.
What are your plans for the headlamp bulbs?
They could probably work well alone as low beams if aimed correctly.I didn't do anything to the aim,the foglight am cuts off right below where the low beam starts,so they don't reach as far as stock lowbeams.
As for the headlights,I've tried two different true HID conversions.
The first system had some glare problems,it wasn't the glare of a high beam but still enough to irritate some oncoming drivers.I was experimenting with additional shielding around the HID burner (bulb) to fix it,almost completed it,then found the other system.
The second system is what's called a bi-xenon system,meaning there's a high beam.Since a burner is a single "filament" and the Tundra/Sequoia bulbs are dual you lose high beams with most HID conversions.The shielding design was different with this system,the glare looked pretty minimal (never got to drive around with them though).I'm not currently using the system because the high beam feature was faulty,they're being sent out for warranty replacement.
quote:
Please explain the details of your fog light HID retrofit. I installed Super Plazmas in my headlights and now the factory fog lights appear too yellow in comparison to the headlights. I'm looking to do something to make the use of low lights & fog lights appear closer in color when both on.
The halogens you have may not be that good of a match.With tinted bulbs the beam color stays pretty much the same at any angle,HID systems vary.You should be able to find those Super Plazmas that fit the fogs (9006 type)
The retrofit is almost a plug-n-play installation.The burners are the same ones found on factory HID headlights but have custom bases added to allow fitting them into an originally halogen light,so they just twist in like the original 9006 bulbs. You'll need to find a spot to mount the ballasts and lengthen the wiring harness wires that connect to the battery positive terminal...that's if the system comes with such a harness,it varies among brands.
If you ladies and gents have any other HID-related questions,feel free to ask,I'm more than willing to answer them to my best abilities
TundraBear
Member # 132
Member Rated:
posted 02-20-2002 09:43 PM
Ed JadeSR5 Tundra,
Thanks! =)
EZ2BME
Member # 97
Member Rated:
posted 02-20-2002 08:50 PM
Nice pics of HID lights. The foglights alone with HID look like they could be used as low-beams.
distribution.
Thanks for sharing....nice work.
John
01 Limited (Jade/Mica) 2WD TRD, XM Radio, Infinity spkrs, Alpine amp, TRD air filter, BORLA split-side catback, Hella Supertone horns.
Posts: 257 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Member # 3
posted 02-20-2002 08:30 PM
Actually they're the factory foglights that I did a true HID retrofit to. Because of the increase in light output they're great auxiliary low beams.
http://www.picturetrail.com/hidtundra
