  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 03-28-2002, 01:13 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:24 AM
nhparrot's Photo Albums
Default Question about stock Tundra Foglights..Help!
Topic: Question about stock Tundra Foglights..Help!
Ed JadeSR5 Tundra
Super Moderator
Platinum TS Supporter
Member # 3
posted 03-09-2002 04:48 PM
quote:
Originally posted by TundraMan:
I don't want to "convert" to HID. The stock housings are not beam pattern corrected for HID and create annoying and dangerous glare.
There's no annoying or dangerous glare when I converted my factory housings to HID. The headlights did though.
Become a TS Supporter by clicking this link
Then check out my corny Tundra website @http://home.att.net/~jadesr5/index.htm
Posts: 67 | From: New Jersey | Registered: Feb 2002 | IP: Logged
iforceV8
TS Supporter
Member # 1174
Member Rated:
posted 03-09-2002 04:32 PM
I talked to a guy at Sylvania about the HID systems @ the LA Auto Show, ( shocked that I knew more about HID kits that he did ) and he said with enough interest the Tundra kit will come out.
Posts: 27 | From: SoCal | Registered: Feb 2002 | IP: Logged
TundraMan
TS Supporter
Member # 145
Rate Member posted 02-15-2002 07:16 PM
None of the HID conversions are street legal. I want the Xenarc foglamps to supplement my stock headlamps. I don't want to "convert" to HID. The stock housings are not beam pattern corrected for HID and create annoying and dangerous glare. The Xenarcs are street legal. Ford and Chevy guys can replace their stock factory housings with Sylvania kits (which include oem headlamp housings, bulbs and ballasts) and are street legal. Maybe someday Sylvania will design housings for the Tundra but its highly unlikely.
TundraMan
Check this out! Live video of the action in front of my house, my Tundra under wraps!!!
2000 Tundra 4x2 SR5 Access Cab V8, Imperial Jade Mica with Oak Interior, Ivan Stewart Signature Edition Package including wheels, TRD Dual Exhaust, JBA Headers, Bilstein Red/Blue Shocks, Chrome Tube Steps, Toyota RS3000 Alarm, Auto Dimming mirror w/temp & compass, El Glo Guages w/blue LED backlighting, JET Chip Upgrade, K&N Filter, PIAA Superwhites, Hella Horns, TundraSolutions license plate frames and a TRD Sticker!
Coming soon: 8000K HID Conversion
My best 0-60 Time using the GTech Pro: 7.4 seconds!
My Vehicles:
'00 "Ivan Stewart" Edition Toyota Tundra SR5 Access Cab V8
'98 Mercedes Benz E430
'02 Acura TL Type S Navi
Posts: 13 | From: Santa Clarita, Ca. | Registered: Feb 2002 | IP: Logged
Tundra00
TS Supporter
Member # 58
Member Rated:
posted 02-15-2002 06:14 PM
TundraMan,
Have you seen these: http://www.fet-usa.com/products/zeta.html
I don't think they are true HIDs, but with these you don't have to replace the light housing, just the bulb. And with these you could do both the headlights and the foglights for about the same price as the Sylvania.
Just a thought.
Tundra00
2000 SR5 V8 Access Cab Black & Tan
Mods: Factory Tube Steps, Bed Rails, Side Rail and Tailgate Caps, Bed liner, Bug Shield, Mirror w/Compass/Temp; Full Time Power Outlet Mod; Backseat Angle Mod; Roadmaster Active Suspension; Bed Extender; Clear Corners; Alpine XM Radio Headunit, 6 CD Changer, JVC 6.5 Components (fr) and 6x9 4-Ways (r), JL Audio Stealthbox, Precision Power 2100 Series Amp; Full Install Handsfree Cell Phone Kit w/Radio Mute
Posts: 64 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Member # 3
posted 02-15-2002 12:16 PM
Tundraman-
Before you decide to replace the foglights with Xenarcs,you should consider doing a true HID conversion to the stock ones.
I converted mine to true HID and really like the results. Spots the low beams miss are now illuminated,and the beam is actually wider than the headlights. With the Xenarcs you get the same results,they weren't designed to take the place of your low beams,just augment them.
TundraMan
TS Supporter
Member # 145
Rate Member posted 02-15-2002 10:18 AM
They have U shaped brackets that are designed to fit under or above the bumper. Physically they are a bit smaller than the bumper openings. Something tells me they need a custom bracket made to adapt to the studs. If I purchase them and can make it happen i'll let you all know. Thanks for the help.
Click here for the installation pictures if you're interested
TundraMan
My Vehicles:
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 02-15-2002 06:34 AM
those are sweet... you sure they'll fit, tho?
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
lelandstanford
TS Supporter
Member # 539
Member Rated:
posted 02-15-2002 05:30 AM
TundraMan:
Could you let us know and post some pics after you install Xenarc?
Factory Add-Ons: running boards, RS3000+
Aftermarket Add-Ons: Bumper Opening Screen, Tint, Carbon Metallic Brake Pads
Mods: DRL & DEF Disabled, Fog Light 2C, Map Lights, Headrests
Posts: 64 | From: Houston, TX | Registered: Feb 2002 | IP: Logged
JDunbar
TS Supporter
Member # 342
Rate Member posted 02-15-2002 05:06 AM
TundraMan,
I know the answer to this one, because I added the factory fogs after I bought the truck. They install from behind. There are 3 nuts that hold the whole lamp holder assembly onto studs that are permanently attached to the bumper. Take off these 3 nuts and the whole assembly drops out from behind.
Peice of cake.
Jeff
Posts: 13 | From: Cincinnati, OH. | Registered: Feb 2002 | IP: Logged
champcaracing
TS Supporter
Member # 182
Rate Member posted 02-15-2002 03:29 AM
can't remember, i had to remove them to install my strobe lights. there are 2 or 3 10mm nuts holding them in, you don't have to remove the bumper for this. remove from the back.
Posts: 6 | From: Clinton twp., MI | Registered: Feb 2002 | IP: Logged
TundraMan
TS Supporter
Member # 145
Rate Member posted 02-15-2002 02:30 AM
Do the Tundra factory foglamps pull out from behind the bumper or from the front?? I was thinking of installing the Sylvania/Osram HID foglamps Click here to view Sylvania's Xenarc foglamps! . I have the Ivan Stuart bumper cover and if I have to remove the foglamps from the front I need to remove the bumper cover in order to remove the foglamp units. If it involves removing the bumper cover i'm gonna forget the whole idea. It was a total pain to put the bumper cover on to start with. Please let me know if anyone has any answers. Thanks in advance.
TundraMan
My Vehicles:
LinkBack to this Thread: http://www.tundrasolutions.com/forums/electrical-and-computer-systems/1969-question-about-stock-tundra-foglights-help/
Posted By For Type Date
Car Classifieds San Antonio, Car Classifieds In Springfield Missouri, Car Clean Air Act - Lonestarbmw This thread Refback 03-06-2009 04:20 AM
01net. - Recherche de hid ip platinum This thread Refback 10-09-2006 11:20 AM
