Fog Light Mod Quirks
Topic: FOG LIGHT MOD QUIRKS
tundra-gearhead
TS Supporter
Member # 103
Member Rated:
posted 03-06-2002 09:49 AM
I've haven't tested to if this happens on my 2000.
But I do like quirk that if you leave the button on, the fog lamps flash with the alarm.
I also like the fact Toyota design the headlights and parking lamps so they can't be left on accidentally if you forgot to turn then off.
Jason
2000 LTD 4WD, Sunfire Red
Posts: 32 | From: Bloomington, IN | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Platinum TS Supporter
Member # 73
Member Rated:
posted 03-06-2002 08:17 AM
quote:
Originally posted by GR8SHOT:
HEY GUYS,
I DID THE FOG LIGHT MOD ON MY TUNDRA THAT KEEPS CONTROL ON THE FOG LIGHT SWITCH. I DON'T HAVE DRL'S. I HAVE NOTICED THREE QUIRKS. THE FIRST I THINK HAS BEEN MENTIONED BEFORE. WHEN THE DASH LIGHTS ARE TURNED DOWN LOW, THE FOG LIGHT SWITCH WILL NOT TURN THE LIGHTS ON OR OFF. THE SECOND THING IS THAT THE LIGHT SWITCH ITSELF ILLUMINATES WHEN THE SWITCH IS ON BUT NOT WHEN THE SWITCH IS OFF. LAST, THE SWITCH ILLUMINATES WHEN YOU TURN THE DASH LIGHTS DOWN LOW, BUT WHEN YOU TURN THEM UP THE SWITCH LIGHT GOES OUT. ANYBODY ELSE NOTICED THIS? I DOUBLE AND TRIPLE CHECKED THE WIRING. IT IS NOT REALLY A PROBLEM, JUST AN INTERESTING QUIRK.
LATER,
TIM
Hmmm interesting.
1. dash lights turned down low - yep thats the way it is because of where the NEW power source is coming from.
2. light on/off - that one is logical, and is set up correctly. You turn on the light, the switch light SHOULD come on to show you they are turned on.
3. I don't have that problem with mine. If switch is on then light is on. But hey I always have my dash lights turned on bright and mine stays on. Not sure about yours.
SATundra
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
GR8SHOT
TS Supporter
Member # 679
Member Rated:
posted 03-06-2002 05:51 AM
HEY GUYS,
LATER,
TIM
2000 TUNDRA SR5 4X4 ACCESS CAB, JADE GREEN, MANIK TUBE STEPS AND GRILL GUARD, K&N AIRFILTER AND BOX MODS, FLOWMASTER 70 SERIES DUAL REAR OUTLET EXHAUST, DELTA DIAMONDPLATE TOOLBOX AND BEDCAPS, KC DAYLIGHTERS, PROCOMP 305/70-16 XTERRAIN TIRES ON EAGLE 589 16X8 WHEELS. MARATHON MOSSY OAK BREAKUP CAMO SEAT COVERS. OPTIMA BATTERY.
Posts: 21 | From: CENTRAL, SC | Registered: Feb 2002 | IP: Logged
