Old 03-28-2002, 01:44 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 11:27 AM
nhparrot's Photo Albums
Default remote start question?
Topic: remote start question?
nhparrot
Moderator
Platinum TS Supporter
Member # 12
posted 03-19-2002 05:37 PM
Wes,
You should use tach mode, so the starter doesn't over crank the engine and the remote computer knows the engine has started . The ECU is behind the glove box. The coil wire mentioned is the front right ignitor when looking at the engine from in front of the truck.
~Glenn~
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
tundrawes
TS Supporter
Member # 7
Member Rated:
posted 03-19-2002 02:48 PM
I just installed a remote start. It has tach and tachless mode. It is in tachless mode now but it takes 2 or 3 cranks to start. I noticed on the electronic faq it said this is the tack wire.
"*1 - You can use the Blue/White on connector E4 of the ECU or the Black/Blue at coil #1 on the drivers side"
can you explain how to get to these wire? Where is the E4 of the ecu??
Thanks,
Wes Reed
wesreed@hotmail.com
2002 Tundra SR5 TRD
True Dual - Dynomax Super turbo exhaust, K&N, Rhino bedliner, Craftman toolbox, Form Fit Bugdeflector, tundra sill protectors, Oklahoma State window sticker!
Posts: 12 | From: Texas | Registered: Feb 2002 | IP: Logged
Old 11-14-2005, 03:35 PM
Dealer : Nye Frontier Toyota/Scion
2005 Toyota Tundra
Last Online: 08-12-2009 04:17 PM
stepperheimer is on a distinguished road.
stepperheimer's Photo Albums
Default CompuStar on 05 DC
I have a 05 Tundra Double Cab. I recently purchased a CompuStar remote started. My question is, do I need a bypass module and if so which one?
Steve
Old 12-05-2005, 03:04 PM
Tundragod's Avatar
Dealer : Rochester Toyota Scion
2005 Toyota Tundra
Last Online: 07-22-2009 01:57 PM
Images: 2
Tundragod is on a distinguished road.
Tundragod's Photo Albums
Please reply if you've done this. I also would like to know. Thanks.
2000 AC V8 4X4 SR5 traded
2005 DC V8 4X4 SR5
Old 12-07-2005, 08:04 PM
Dealer : Schaumburg Toyota
2001 Toyota Sequoia,
2008 Scion tC
Last Online: 07-17-2009 10:35 AM
JohnnyStep is on a distinguished road.
JohnnyStep's Photo Albums
Yes, you will need a bypass module for your remote start system. You should have no problem using another manufacturer's bypass module with the Compustar remote start. In fact, I'm thinking about buying a Compustar remote start/alarm system, and was told that I can use a DEI bypass module with the Compustar 2W900FM-AS.
What I would do is go on ebay and find someone selling the same model remote start system that you bought. Send them an email and ask what model bypass module they recommend for your Toyo. Even if they don't sell the bypass modules, you should be able to find another person selling one.
When you get it hooked up, post again to let me know how you like the Compustar. That model is supposed to have a top range of 3000 feet outdoors!
