Cargo/center brake light melting
+ Reply to Thread
Results 1 to 13 of 13
Thread: Cargo/center brake light melting
  1. #1
    Rookie Erkme73's Avatar
    Join Date
    Feb 2002
    Location
    central florida
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    Default Cargo/center brake light melting
    I did a quick search and couldn't find any similar posts - although, I can remember '00 users discussing this several years ago - so I'll post a new thread.
    My center brake light burned out recently, and when I went to change the bulb, I found that the silver plastic housing (beneath the lens) had been melted and bubbled pretty badly :cry: . Also, the gray plastick sockets were discolored, and slightly deformed. The lens showed no signs of heat stress.
    I called the dealer to ask if they knew of any heat/melting issues. They said no. I also checked alldata.com, and found not recalls or tsb's on the center light.
    Has anyone found this kind of damage on their truck? Since the cargo and brake bulbs are the same, I temporarily swapped them - until I have a chance to buy a new one from Autozone. I guess it'd be nice to get an LED replacement like those for the back brakes.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    19 times
    Rep Power
    1673
    Quote Originally Posted by Erkme73
    On the '00 there was a recall on some early production models for the stop/taillights and a tsb on the dome lamp. But no TSB's etc on the cargo lamp. If the socket is not holding the bulb tightly, there may be discoloration, the use of higher wattage bulbs may cause the symptoms you are seeing, or eater leakage into the assembly could be a culprit.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  4. #3
    Here for the long haul... warrior's Avatar
    Join Date
    Dec 2002
    Location
    DSOTM
    Posts
    224
    Liked
    0 times
    Rep Power
    13
    My 2001 cargo light (third brake light cover) has "melted as well. The red part (brake light) is fine but both of the white lens side are "melted". The bulbs are in and working fine and I haven't actually popped the lens cover off yet but it is nice to know it wasn't just mine....
  5. #4
    Junior Member gator2764's Avatar
    Join Date
    Feb 2002
    Location
    McDonough Georgia
    Posts
    144
    Liked
    1 times
    Images
    2
    Rep Power
    13
    Changed my cargo lights out a few weeks ago and noticed the "melting" on mine as well. One thing you don't want to do is touch those damn lights while they are hot!
  6. #5
    Junior Member rizico's Avatar
    Join Date
    Sep 2003
    Location
    LULING, TX
    Age
    32
    Posts
    268
    Liked
    0 times
    Images
    3
    Rep Power
    12
    Unhappy Same Here
    MINE ARE DISFIGURED AS WELL UNDER AND ABOVE EACH CARGO LAMP BULB, AND ON ONE SIDE IT HAS MELTED THE SOCKET TO THE EXTENT THAT THE BULB HAS A SLIGHT SHORT AND DOESNT WORK ABOUT 10% OF THE TIME. I HAVE NOT CHANGED TO A HIGHER WATTAGE BULB, THES ARE STOCK, 921 BULBS. I DID REPLACE WITH LEDS FOR A WHILE BUT THEY KEPT BURNING OUT. MAYBE ITS A CONNECTION ISSIUE IN THE SOCKET, OR A VOLTAGE SURGE ISSUE, WHO KNOWS, BUT I DO KNOW THAT IT'S HARD TO BURN OUT AN LED WITHOUT HAVING THE "WRONG" VOLTAGE GOING THOUGH IT.
    Quote Originally Posted by gator2764
    2007 Tundra CrewMax 4X4 Limited
  7. #6
    Join Date
    Feb 2002
    Location
    Baltimore, MD
    Age
    47
    Posts
    35
    Liked
    0 times
    Rep Power
    13
    Default Cargo Lamps Melted wholes in plastic bulb area!
    I just went to change my bulb in the cargo lamps, and found that there were big wholes melted straight through above the lights. I noticed only a couple of you saying you had this problem.
    I'm surprised that Toyota doesn't fix this. It seems to me, that maybe it could start a fire.
    Have anymore of you had this problem. I didn't know about it, until I took the plastic cover off.
    Thanks,
    Doug
    Proud owner of a 2002 Tundra and Sequoia.
  8. #7
    Supporter Todd3834's Avatar
    Join Date
    Dec 2003
    Location
    Huntington Beach
    Age
    28
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Unhappy Burn Baby Burn
    Yea... This is a problem with my 03' Tundra too. A while back one bulb burnt out so I replaced it with a bulb I bought @ Autozone... But today I noticed the other one burnt out so I pulled the cover off and noticed the stock bulb burnt a whole completly through the plastic. So I put another replacement in. It seems like the stock bulbs were getting hotter then my replacement bulbs... I dont get how it can get hot so fast though... I mean the cargo lamp isn't on that much is it?
  9. #8
    Supporter TwinStop's Avatar
    Join Date
    Oct 2004
    Location
    Twin Falls, ID
    Posts
    243
    Liked
    0 times
    Rep Power
    11
    Mine has been hot also. And they would not work sometimes usually the left one if I banged on the cab it would come on I thought it was loose wiring or something took it apart and all looked good changed bulbs and its worked fine ever since.
  10. #9
    Join Date
    Nov 2010
    Location
    Lewisburg, OH
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Re: Cargo/center brake light melting
    While changing a burned out bulb in my 2002 Toyota Tundra cargo lights, I also noticed holes burned through both the left and right bulb housings. The burned out bulb was white and broke in my fingers when I tried to remove it. I finally pulled what remained of the bulb out with pliers. I checked the other two bulbs and found they had numbers that were different from those listed in the owners manual. They were 906's instead of 921's. I thought, ah ha, someone put the wrong bulbs in the cargo lights and they melted the housing. I then did some checking on line and found that the 906 bulbs are rated at 13 volts and 8.97 watts whereas the 921 bulbs (the ones the owner manual recommends) are rated at 12.8 volts and 17.92 watts. I have since concluded the original 921 bulbs caused the housing to melt and either the previous owner or the dealer replaced all three bulbs with the lower wattage 906 bulbs. The only thing I haven't figured out is why the one 906 burned out and turned white.
  11. #10
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Rep Power
    268069
    Get yourself some high powered LED bulbs instead.
    Attention environmentalists, reduce emissions from this:
  12. #11
    Join Date
    Feb 2007
    Location
    Dover, NH
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Your experience exactly mirrors mine. I also had the white bulb which broke in my fingers and the silver plastic housing above each of the bulbs was melted to the extent that there was a hole above each bulb. Mine is an '06 Extra cab. This has been going on since 2000 and yet Toyota says it never heard of the problem! I guess one will have to catch on fire before they take notice. The replacement bulb is the 921. As for the "white" bulb which broke in my fingers, I'm guessing it got wet. When I pulled the lens off i noticed the rubber seal was not seated properly in the corner above that bulb.
  13. 08-29-2011, 10:31 PM
    Banned
    Reason
    Spam
  14. #12
    Join Date
    Jun 2008
    Location
    Atlanta, ga
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Same thing here. I put some reflective metal tape over the holes and ordered these T10 194 168 501 921 W5W 28 LED 3020 SMD Car Side Wedge Light Bulb Lamp White 12V | eBay
    Hopefully they are bright as the originals.
  15. #13
    Junior Member Iron Clad Lou's Avatar
    Join Date
    May 2007
    Location
    Irwin, PA
    Posts
    295
    Liked
    13 times
    Images
    4
    Rep Power
    258
    any chance you guys are leaving the cargo lights on while you drive? as Mr. Creosote said, go with the high powered LEDs instead.
    2004 DC Limited, Husky Liners, 35% window tint, fog light mod, map light mod, Hoen Fogs, 265/70/17 BFGs, color matched wheels, Bazooka sub, resonator removed, full LED conversion.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
