Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Old 03-30-2002, 04:19 PM
tundrawes's Avatar
Dealer : Metroplex Toyota
2002 Toyota Tundra
Last Online: 11-06-2009 05:10 PM
Images: 9
tundrawes is on a distinguished road.
tundrawes's Photo Albums
Default AC outlet
Has anyone installed any ac outlets in their truck? What are the best systems to use?
Old 03-30-2002, 06:34 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
I use a small power inverter that I plug into the lighter for when I use my laptop on the road. I got it pretty cheap for $25, but it wont handle much more than my laptop.
Old 03-31-2002, 08:24 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 08-24-2009 12:34 AM
SATundra is on a distinguished road.
SATundra's Photo Albums
I haven't YET, but Sam's has a 400 watt inverter right now for $29.95, and I am gonna pick one up soon.
I can't remember the Members name, but someone had even installed a plug in the dash just above where your right knee is, in that recessed area. That setup looked pretty nice. They used to have pics posted but that was before the big crash and I haven't seen them since.
SATundra
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 03-31-2002, 11:53 PM
tundrawes's Avatar
2002 Toyota Tundra
Images: 9
Question
I sure would like to see the pics! I also would like to install mine in the dash.
Old 04-03-2002, 11:58 AM
Dealer : Centennial Toyota Scion
Last Online: 03-10-2006 11:03 AM
T'sTOY is on a distinguished road.
T'sTOY's Photo Albums
I installed a 600W inverter in my Mom's two vans as she's on oxygen and uses either a bottle or a concentrator.
If you plan to power anything more than 200-300 watts, here are a couple of things to consider:
1) Use the largest gauge copper wiring you can get. I went with what I believe was either 4 or 6 gauge battery cable from my local NAPA parts store.
2) It's also recommended that you keep the wiring from the battery to the inverter as short as possible.
3) They also recommend the use of an inline fuse to protect the inverter.
I can't remember for sure, but I either couldn't find a fuse large enough to handle the load or the fuses available were rediculously priced, so I went with a 50 Amp (?) breaker that I picked up at my local RV store. The electrical technician I talked with highly recommended the breaker over a fuse since if it does happen to trip, it will reset and you don't have to worry about replacing fuses.
She's been using it for a couple of years now with no problem, other than a bad battery. The inverter started shutting itself down fairly regularly. I did a little investigating and found that her Diehard battery was defective. Once we replaced the battery the inverter worked fine once again.
On her Previa, I just installed the inverter next to the driveline hump or bulge on the passenger's side. It's by no means a clean installation, but it's within easy reach for her to turn on and off as needed.
Good luck,
T
Old 04-04-2002, 12:11 AM
SATundra's Avatar
Good info, thanks T. I did buy that 400 watt inverter but haven't installed it yet.
SATundra
SATundra
MODS:
TIRES:
SUSPENSION:
