Old 12-20-2003, 09:09 AM
Last Online: 04-03-2005 04:15 PM
Tundratow is on a distinguished road.
Tundratow's Photo Albums
Default Truck cap/3rd. brake light question?
If you have a truck cap with the "third brake light", can you tell me how they ran the wires to tap off of the rear tail light? Did they need to drill any holes?
Thanks
Old 12-20-2003, 12:16 PM
ricqik's Avatar
Last Online: Yesterday 08:48 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
Mine was tapped into the left brake light.
There's a little 1/2" hole in the rear of the bed that is located 3" from the top of the bed and 7" from the rear. Take your left tail light out and run the topper light wires through this hole and work the wires through towards the tail light area. Use a 12V light probe to find the stop light wire and splice into it. If your topper wire is routed to the right side do the same thing.
Old 12-20-2003, 06:09 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
Yep, thats how they ran mine as well. Also they ran a hot wire to battery to run the inside canopy dome light if you got that option. Just outside the opening where the hole is, is where there "should" be a plug, so if you remove the cap its one simple plug and 4-6 clamps and it's off.
They should not need to drill any holes!
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 12-20-2003, 06:22 PM
Thanks guys,now I can make sure the installer runs it that way and doesn`t drill any holes.
