Brake controller removal wires
+ Reply to Thread
Results 1 to 3 of 3
Thread: Brake controller removal wires
  1. #1
    Rookie Rooks is on a distinguished road.
    Join Date
    Jan 2011
    Location
    Nevada
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Default Brake controller removal wires
    I've got an '01 Tundra that has a Tekonsha Voyager controller installed. I didn't install it (I'm not original owner). I'd like to remove it as simply as possible so that the it is no longer connected to my stoplight switch because I believe it may be causing an electrical issue I am having, it's not working properly, as well as I see it was not grounded the recommended way on Toyotas. Can I just cut the stoplight wire of the controller without effecting my truck just so I can quickly rule out the controller as one of my causes? The stoplight wire from the Voyager runs through a connector to a truck wire. Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation.
    Join Date
    Apr 2012
    Location
    Wv
    Posts
    55
    Liked
    7 times
    Rep Power
    684
    Default Re: Brake controller removal wires
    Can you not simply unplug it from the back of the controller?
  4. #3
    Join Date
    Jan 2011
    Location
    Nevada
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    No, it was hard-wired in. I had Toyota do it. That wasn't the issue-it did end up being the alternator slowly dying--replaced it last night. Thanks for all your help, though, guys.
    Sent from my DROID X2 using AutoGuide.Com Free App
Posting Permissions
  • You may not post replies
  • You may not edit your posts
