I did a fuse box mod using the fuse taps to make it operate normally but only when the key is on. All you do is pull the correct fuse, plug the correct fuses into the tap and plug the taps in where the fuse was. I don't think this mod survived the big TS computer crash. It's pretty easy if this is the way you want it to operate. There was a power plug mod like this also using the taps a while back if you want to keep one hot all of the time. You do need to be careful which way you plug them in and the correct way to configure the fuses in the taps. This avoids cutting wires in the factory harness.
Fred.
So far;
Yeasu FT-8800 Amateur Radio, Rugged Liner, DuraHitch reciever w/7 pin light plug, Fog light mod w/custom indicator, Rear seat mod, Mobil-1, Spin on tranny filter, Magnefine power steering filter, Hellwig rear sway bar w/addco links & extra bolt, Formfit hood deflector, Almost free alarm upgrade, Sequoia split three wheels W/Yokohama H/T-S, Seat belt mod, Aux backup lights, De-badged, AC in derfost mode mod, Osram SilverStars, EnergySuspension Poly/greasable front swaybar bushings, Odyssey PC1200MJT Battery, Fumoto valve, R.A.S., XM w/USA Spec. TRD 4x4 Coilovers w/Bilstiens all around... When will it end!?!?...
