Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Free Shipping at Buy.com!
FREE Personal Trainer Program
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Fog Light Mod Question", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-22-2004, 08:17 PM
T3Mike's Avatar
T3Mike's Photo Albums
Last Online: 06-15-2007 08:44 AM
T3Mike is on a distinguished road.
Question Fog Light Mod Question
Today I did the Fog light mod, and it works awesome. My Question is should the fog lights turn off with the truck? Right now when I have my Fog lights turned ON They stay on when I shut my truck off. Is this the case for all? or did I do somthing wrong?
2003 T3 Tundra (canadian)
- Dual Borla Exhaust, 17" titanium Wheels, Borla Performance intake, PIAA H4 Headlamps, PIAA 9006 Fog Lamps, Alpine IVA D-901 DVD player, Alpine PXA-H701 Digital Signal Processor
Old 01-22-2004, 09:28 PM
mandzach's Avatar
mandzach
Dealer : Findlay Toyota Scion
2003 Toyota Tundra,
2007 Toyota Tacoma SILVER-DC-OR-4x4
mandzach's Photo Albums
Last Online: 10-12-2007 11:40 PM
mandzach is on a distinguished road.
Default i thought that also
make sure you have the lights on then shut truck off and see if they go off - if the truck is shut off mine go off but if i just hit the switch they turn back on with the truck off. -also do the security mod -look up $20 rs3200 upgrade - i did it when i did my fog light mod and i found a cool side affect - if you leave the fog lights on but shut off the all other lights when you shut the door and arm the alarm the parking lights flash and the fog lights to... it looks real cool to me thought you might like that. -make sure you do the $20.00 upgrade not the other ones listed -it uses a part made by toyota that fits in your dash- if you have any questions let me know.
2007 Tacoma 4x4 DC/SB - Total Chaos UCA's, Donaho Racing CO's, Deaver Springs, 33" Toyo MT's
.................................................. .................................................> Built for Desert Fun!
Need Tranny Mods?--> IPT Valvebody calibration IPT Transmissions
Old 01-22-2004, 10:05 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: Yesterday 11:06 PM
SATundra is on a distinguished road.
I have an '01 not an '03 (the mod might be different) but mine turn off with the truck. Only time they come on is when the parking lights get turned on. At least on the '01 mod the wire you tie (splice) into is the parking light circuit. So it makes sense whenever the parking lights are on the fogs are on, as long as the fog light switch is left in the ON position. And yes my fogs also flash with my alarm arm/disarm.
Cant speak for the RS3200 mod as my alarm is aftermarket.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 01-22-2004, 10:15 PM
T3Mike's Avatar
No they dont turn off, The only way the fog lights turn off is if I turn them off. I tried all options and they stay on unless I switch them off.
did I possible patch in the wrong wire?
Old 01-22-2004, 10:32 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Today 05:55 AM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
sounds like you wired them to an always live circuit. What instructions did you follow?
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 01-23-2004, 03:58 PM
dondi40here's Avatar
dondi40here's Photo Albums
Last Online: 07-11-2005 08:57 PM
dondi40here is on a distinguished road.
I did the mod and mine also stayed on all the time unless I turned them off. But I think this was becuase I had did the power outlet mod to keep them hot all the time by removing the relay and jumpering the input power to the relay to the output side of the relay with a short piece of wire. So what I did was remove the coil wire for the power outlet relay and install it in the coil slot for the foglights relay which gives me power to the relay only if the truck key is turned on.
Old 01-25-2004, 01:55 AM
Dealer : Clint Newell Toyota
2002 Toyota Tundra
Toadswift's Photo Albums
Last Online: 04-21-2007 07:32 PM
Toadswift is on a distinguished road.
I just powered them from the fuse panel left of steering colum..... on the ignition side and they go off when I turn the key off. I like to use them as DRLs as, even though I ordered them I did not get them.
I guess I should say activate them from the fuse panel, as I still use the relay. Can turn off/on with the switch also and use with highs or lows.
Old 01-25-2004, 09:08 PM
hendricksonl's Avatar
hendricksonl's Photo Albums
Last Online: 06-18-2006 01:15 PM
hendricksonl is on a distinguished road.
Just FYI, I did the foglight mod but instead of powering off the power outlet fuse (cuz wanted them on only as driving lights when headlights on - have DRL already) ended up tapping off of pin 1 on DRL No 4 relay (just made room for the wire under the relay off to one side and then fed the wire thru the hole in the lug on the Relay and pushed it in - was planning to solder it later but fit's so tight I don't think I can get it back out so has pretty good contact so s/b ok). What this does is take power from the head lamp relay before it gets split in the dimmer relay into highs or lows. [ref 2003 EWD and 2003 relay location PDF files]
