2010 Tundra wire running for light bar
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2010 Tundra wire running for light bar
  1. #1
    Rookie ERock62 is on a distinguished road.
    Join Date
    Feb 2013
    Location
    Ontario CA.
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default 2010 Tundra wire running for light bar
    Just picked up a 2010 Tundra DC 4x4 last weekend and I am planning on installing a 20" lightbar I have soon from my old jeep. Where is the best place to run the wires through the firewall into the cab? Thanks!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some. dixondn has done just about everything...and then some.
    Join Date
    Sep 2008
    Location
    Colorado
    Posts
    86
    Liked
    9 times
    Rep Power
    995
    Default Re: 2010 Tundra wire running for light bar
    Pull the driver side panels on the floor and there is a huge grommett that you can use. Or I ran two 1/0 power cables through the firewall in the same location and then down the cable trays to the back wall of my Crew-Max
  4. #3
    Join Date
    Feb 2013
    Location
    Ontario CA.
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by dixondn View Post
    Thanks, I will check out the location this weekend.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
