Old 02-06-2004, 11:57 AM
F1Jim's Avatar
Dealer : Team Toyota Scion
2006 Lexus GS300
Last Online: 10-22-2005 05:05 PM
F1Jim is on a distinguished road.
F1Jim's Photo Albums
Default Adding light to interior?
I'd like to add a footwell light to the front passenger side of my '04 Sequoia to match the driver's side? I plan on finding a similar bulb and housing as the driver's side and wiring it directly from the driver's side light. Should I wire it "in line" or "in parallel" with the light on the driver's side? I don't want to reduce the light output from the driver's side light, nor do I want to overheat or blow any fuses, etc.
thanks!
Jim
Old 02-06-2004, 12:02 PM
derone's Avatar
Dealer : Leith Toyota
2001 Toyota Tundra,
- Other -
Last Online: 11-08-2009 11:18 AM
Images: 6
derone is on a distinguished road.
derone's Photo Albums
In Parallel with the other light is what to do if you want both bulbs to see the same voltage and hense, brightness.
Doug
Old 02-06-2004, 12:37 PM
F1Jim's Avatar
2006 Lexus GS300
Jim
Old 02-06-2004, 07:56 PM
F1Jim's Avatar
2006 Lexus GS300
On a related note, does anyone know what kind of light is used for the footwell on the driver's side? Is it a "37"? And where can I get a socket? I found plenty of sources for the bulb (if 37 is it), but no one seems to have a socket
thanks
Jim
Old 02-06-2004, 08:41 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Today 12:36 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
thanks
Jim
If I'm not mistaken your owners manual will list all the bulb types for your vehicle. A good auto parts store should be able to provide the lamp socket with a wire pigtail to match the lamp.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 02-06-2004, 08:53 PM
F1Jim's Avatar
2006 Lexus GS300
I must not have any good auto parts stores nearby. Neither Napa nor Advance Auto had the socket for the tiny bulb.
The manual lists most lights, but doesn't mention the footwell bulbs. I'm 99% positive they are called '37' or '73'.
Jim
Old 02-06-2004, 09:08 PM
LGL002's Avatar
Images: 17
Jim
No Auto Zone, Pep Boys, Checkers? I'm not sure to be honest if my Tundra has those footwell lamps or not. I'll have to look.
Optima 34R battery
Old 02-06-2004, 09:10 PM
F1Jim's Avatar
2006 Lexus GS300
We have Autozone. I'll give them a shot tomorrow.
Jim
Old 02-07-2004, 01:59 PM
F1Jim's Avatar
2006 Lexus GS300
As impatient as I am, I went ahead and soldered a length of 22 gauge speaker wire to the leads on a #73 bulb I found in my garage. I secured the light under the passenger side dash, ran the wire across to the factory footwell light and used "quick splices" to connect the new lamp in parallel with the original one. DONE!
