Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Free Shipping at Buy.com!
FREE Personal Trainer Program
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Auxiliary reverse lights", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 11-22-2004, 10:55 PM
Dealer : Karl Malone Toyota
hiro24601's Photo Albums
Last Online: 03-26-2008 07:07 PM
hiro24601 is on a distinguished road.
Default Auxiliary reverse lights
I know the moderators get miffed when somebody posts a new thread before doing a thorough search.
There are many threads out there addressing auxiliary reverse lights. Most are tied into the cargo lights. BRILLIANT IDEA! Thought about it for a while and I need something different.
I want to hook my auxiliary reverse lights to a relay and a single pole/double throw (SPDP) switch. Where they will activate when the reverse lights go on, when I flip the switch or remain off if I please. I have a LED light to install in the dash so I know they are on.
My question is:
Where do I tap into the reverse lights?
I pulled off the lens on the back of my truck. I found two wires going to and from the "reverse lights". One Red with a Blue Stripe and the other White with a Black stripe. My reverse lights work, so the "+" wires must eventually lead go to a relay (or many relays) then to the battery. The "-" lead to a ground.
Where do I tap into the "+" wire?
In my old truck I pulled out the passenger seat. My girlfriend shifted the vehicle from N to R while I tested the wires with a voltammeter. Took a while but I found it.
Furthermore I have a Haines repair manual and I've searched and searched for the R/L wire and I can't find it! In my old truck there was a schematic of all the wiring harnesses. There was actually an exploded view of the truck and all the wires.
Now I have T/S! Please tell me one of you has some info...
My girlfriend thanks you!
Old 11-22-2004, 11:50 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Yesterday 07:04 PM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
My question is:
See the Miscellaneous Lighting page of the FAQ: TundraSolutions.com Lighting & Electronics
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 11-23-2004, 02:10 PM
Talking Found it!!
Found the wiring diagrams! Thanks Glen, I'm still learning how to navigate this site.
Old 11-23-2004, 02:59 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: 08-01-2008 09:58 PM
SATundra is on a distinguished road.
I have installed the auxillary reverse lights on my truck, using a relay as you are looking into doing. I located the reverse light trigger wire underneath the drivers seat where it goes from inside the cab to underneath the truck. I mounted the relay inside the drivers side kick panel. Theres enough room in there for at least 3 relays. I have 2 installed already. Good luck it's not that big of a job to install.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 11-23-2004, 04:14 PM
TwinStop's Avatar
Dealer : Wills Toyota
2006 Toyota Corolla,
2001 Toyota Tundra Limited,
1994 Toyota Truck
TwinStop's Photo Albums
Last Online: 06-26-2008 12:15 PM
TwinStop is on a distinguished road.
Default 50 Watt backup lights
Anyone try anything like thse 50 Watt Halogen. I'm thinking about it but I concerned about the heat they'll put out, I havent checked the wattage on our stock ones yet.
http://www.designtech-intl.com:8080/...atid=12&step=4
Old 11-23-2004, 04:43 PM
Stargazer's Avatar
Dealer : West Coast Toyota
2003 Toyota Sequoia
Stargazer's Photo Albums
Last Online: 08-26-2008 11:13 PM
Stargazer is on a distinguished road.
I had the 50w halogen backup bulbs in my Passat. The warning in the instructions said not to be in reverse for more than 2 minutes otherwise the housing could be damaged. That wasn't a problem for me because there would no reason that I would need to be in reverse for that long.
There's a definite difference in brightness from behind the vehicle and I've attached a picture that compares it to the stock 21w bulb.
Was there a difference from behind the wheel? I'm not sure. My windows were tinted pretty dark so I'm not sure if I could tell. Even so, I felt better that they were there. I would definitely have bought some for my Sequoia but they don't use the same bulb type.
The living are just the dead on holiday.
2003 Sequioa LTD ~ Phantom Grey (sold): Stargazer's Garage
Old 09-15-2007, 05:30 PM
Dealer : Brown's Charlottesville Toyota
2002 Toyota Sequoia
jtp7571's Photo Albums
Last Online: 09-16-2007 03:22 AM
jtp7571 is on a distinguished road.
Default Re: Auxiliary reverse lights
can't do a FAQ search. I am trying to hook up the back up light to my horse trailer but there seems to be a problem. You see I have a plug that allows me to plug the existing 4 pin into it and then all I had to do was hook up the blue wire to the electric bakes, the black wire to the battery and the white wire to the ground. Well it seem to me that hooking up the big wire to the ground is by passing the one that already exists in the 4 pin. Is this the case and does anyone have any suggestions?
Old 09-15-2007, 07:18 PM
tooldud's Avatar
Dealer : Leith Toyota
2003 Toyota Tundra
tooldud's Photo Albums
Last Online: 02-24-2008 08:51 PM
tooldud is on a distinguished road.
That's were I found my reverse wire too. I went another step and wired them and my reverse camera to a switch so they always come on when in reverse, and I can turn both on anytime I want to.
Here are my rear lights.
Tom
03 AC SR5 Silver Sky Metallic
Cab height ARE cap, Westin chrome step bars, tinted front windows 35%, Hella mini foglights under front bumper ,fog lights under the frame to light up the door area, fog lights under rear bumper (factory dash switches for each set of lights),Bedrug, Hellwig swaybar, one-touch window control for both windows,Kenwood DDX-6019 double din dvd unit,2 amps, 2 sets of speakers, 6 disc cd changer,Q-logic sub box, subs, rearview camera, & skid plate.
Freebies: Power outlet mod,fog light mod, map light mod &, debadged.
Hope to add: Chrome bull bar, headest monitors for back seat passengers (daughters)
Waiting for time to install: kicking alarm w/remote start.
My Website
Old 11-06-2007, 06:39 AM
Dealer : Mic Mac Motors
- Other -
hrdneglcry's Photo Albums
Last Online: 11-08-2007 09:54 PM
hrdneglcry is on a distinguished road.
I know that this thread is really old, but did you ever find out how to tie the reverse auxiliary lamps directly into the the reverse lights?
Old 11-07-2007, 09:47 AM
Dealer : Sun Country Toyota
KXcam's Photo Albums
Last Online: 08-17-2008 11:15 PM
KXcam is on a distinguished road.
The reverse light circuit does not have enough capacity to run BIG reverse spotlights. You need to run a separate power wire from a fuse.
5.7L 4WD CrewMax, Silver Sky, TRD, Remote Starter, Sill Plates X4, Color Matched LineX.
Old 11-07-2007, 02:58 PM
- Other -
So I cannot tie reverse spotlights 55 w each into the reverse wire? What would happen? They just would not turn on? On a Wiring diagram I ran the lights into the reverse wire with no luck. I have the lights hooked up to a relay, and a switch now. Usually I disconnect the switch wire, and run the new wire from there into the wire operating the light I want to use. The original poster seems to have wired his lights into the reverse wiring. So is there no way to make the spot lights come on automatically with the reverse lights? Or do I keep the relay wired into the fuse, and also run it into the reverse wire??????? Thanks in advance
Also the lights are hooked up, and run fine now from a switch. i'd really like to run them through the reverse lights though, so that they will come on automatically when the reverse lights are engaged. So far no luck getting them to come on with the reverse lights.
I would not mind having the opton of running them from the switch, and the reverse lights. Meaning that I'd like the option for them to come on automatically with the reverse lights, or manually with the switch when the reverse lights are not engaged. But the switch cannot stay in the on position. Only when I want it on for manual operation. Hope this is clear enough.
Old 11-07-2007, 05:17 PM
Eddie's Avatar
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Eddie's Photo Albums
Eddie is on a distinguished road.
The factory wiring would overheat,insulation will melt,something will short circuit and blow a fuse.
You probably tapped into the factory reverse lights' ground instead of positive. Get a test light or multimeter and verify what's ground and what's positive.
There's a way you can still switch the lights even with the reverse lights off,but fix the original problem first. You will need an additional relay to do this.
Old 11-07-2007, 05:21 PM
- Other -
Is it the same with the trailer tow lights? I cannot tie into them either? So how can I install reverse auxiliary lights? Tooldud was able to do his..................
Old 11-07-2007, 06:03 PM
LifeTech's Avatar
Slummin'
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
LifeTech's Photo Albums
Last Online: 08-30-2008 10:23 AM
LifeTech is on a distinguished road.
1) Make sure your existing polarity is correct as stated above.
2) ONLY USE THE REVERSE + POS TO POWER THE RELAY INSTEAD OF USING THE REVERSE + CIRCUIT TO POWER THE ACTUAL LIGHTS THEMSELVES. bECAUSE THEY WILL OVERLOAD THAT CIRCUIT. yU NEED A DEDICATED CIRCUIT TO POWER THE AUX. LIGHTS. The existing reverse circuit is to trigger the relay, much like the manual switch would do.
Old 11-07-2007, 07:38 PM
- Other -
OK, not to collude this thread, but on my regular front auxiliary lights I used the relay, and wired them right into the bright lights. I also, once tied them into the fog lights. I mention this because I know how to tie lights into other lights, and into the relay to run when the lights are activated. But I have been unable to do so with the reverse lights. It is not a hard operation to do. But I cannot get the lights to activate when they are wired into the reverse light wire. I do wait for the reverse lights to engage, before I determine if the auxiliary lights are on, or not.
