Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Old 01-17-2005, 02:12 PM
TEFye's Avatar
Dealer : Bert Wolfe Toyota
2005 Toyota Tacoma
Last Online: 11-03-2009 10:16 PM
TEFye is on a distinguished road.
TEFye's Photo Albums
Default Auto Dimming(EC) mirror w/Homelink for 05 Taco
While I was searching for the Taco that I wanted, I noticed that Toyota SE region offered an EC mirror with Homelink. No other region offered that accessory & I had already agreed to purchase an o5 Dbl Cab with Sport pkg, that should be in this week. Since the sport pkg has a temp and compass readout, this mirror was perfect - auto dimming and homelink only! I emailed 2 dealers in SE Toyota region and Town & Country Toyota, Charlotte, NC responded with an offer offer of $149 + $8 shipping. I called, talked to Bill & it is on its way. Probably any SE Toyota dealer would sell the mirror, but $149 is a good deal as retail is $279.
Old 01-17-2005, 03:00 PM
Last Online: 02-01-2006 11:26 PM
disabati is on a distinguished road.
disabati's Photo Albums
Default Check Out Ebay for an Auto Dimming Mirror
I bought a Gentex GENK-40 auto-dimming mirror off of ebay for around $70. This worked out perfectly. As you point out, the Sports Pkg already has the compass and outside temp. So, auto-dimming and Homelink is all you need.
First piece of advice, after calling several Toyota dealers who mostly gave bum advice, the way to remove the old mirror is to tap gentley using a rubber mallot from the bottom and the old mirror will slide upward and off the windshield mount. DO NOT attempt to pry the mirror toward you as several dealerships indicated to do. What appears to be a plastic housing on the stock mirror is actually one piece. Prying will likely shatter your windshield.
If you look under the stock mirror while it's mounted, you will notice a narrow slot on the bottom. There is actually a locking clip that you should use a small screwdriver to disengage. However, I didn't know this until after removal, and, the old mirror came off for me w/o damage. You just need to be gentle.
Second piece of advice, suggest using the power source from the overhead console. It's convenient and relatively easy if you know what to do. First, remove the overhead console. Do this by opening the sun-glasses storage compartment and you'll see a phillips head screw; remove it. Next, the console is held in place by two clips near the front. Simply pull downward with a fair amount of force. In my case, one of the clips came apart (did not break). But, it was simple to reassemble. Next, disconnect the two wire harness plug assemblies and set the overhead console aside. Now, you just need to figure out which wires to connect to. For the Homelink system, use the dome light positive lead (you always want power to the Homelink buttons, even when the ignition is turned off). I don't remember which wire that was (I should have taken pics), but, with a volt meter, this is a relatively simple task to figure out. For the auto-dimming power source, use the positive lead that the outside temp gauge / compass use (that means the power source turns off when you turn off the ignition). Again, a volt meter will tell you which wire that is (if I recall correctly, it was the thickest of the wires going into that plug). For the mirror's negative lead, I used the dome light's negative lead. For splicing into the wires, suggest going to Walmart and buying a pack of the smallest 3M wire splicers (they're in the automotive section near replacement light bulbs); these worked just fine.
One last piece of advice for a nice finished look - The mirror I bought on ebay, which by the way came out of a Murano, had a wiring harness consisted of 3 loose wires (1.Homelink, 2.Auto-Dim, and 3.Ground). I used the sheathing from an old computer monitor cable to form the jacket over those wires. The results gave a factory appearance. From the computer monitor cable, I cut a length of about 8 inches or so and removed the existing cable from the jacket or sheathing (the outer layer). Using dish soap, I coated the 3 wires from the mirror plug and fed them into the now hollow wire jacket. I must admit, I didn't think the wires would feed all the way through, but, they did. Once the mirror is mounted, you can feed wires through the notch located in the headliner (note, you need to do this before you make your final connections).
I installed mine about a month ago and haven't had any problems with overloading the circuit (i.e., blowing any fuses). The job took about 3 hours, but, most of the time was spent figuring out what you now know. If you are comfortable with wiring 12-volt systems, I think you'd find this to be a relatively easy task. Hope this helps anyone considering to do the same. I've attached two pics of the finished result.
Front View
View from Behind Mirror
Auto Dimming(EC) mirror w/Homelink for 05 Taco-mirror1.jpg   Auto Dimming(EC) mirror w/Homelink for 05 Taco-mirror2.jpg
Old 01-17-2005, 03:15 PM
TEFye's Avatar
2005 Toyota Tacoma
Default EC mirror advice
Thanks a million for the install advice. I had been searching some of the aftermarket mirror sites for install instructions and it was scary!! One even said to pull down sharply for the 05 Tacoma, but be carefull, as you could break the windshield. NOW, how to you pull down sharply and still be carefull?
Actually, since mine is a Toyota accessory, I was considering going to the local dealer(they have a really good svc dept), and if they broke the windshield, they would have to replace it. But, now with your advice, I will give it a go myself. If the mirror turns out to be obstinate, then I'll run to the dealer. Thanks again, you probably saved me some $. I'll post the results later - my truck is due in any day now. Now to hardwire the radar detector and get a sub behind the rear seat. . . .
Old 01-26-2005, 04:53 PM
TEFye's Avatar
2005 Toyota Tacoma
Default EC mirror w/Homelink installed!!
Picked up my 4X4 dbl cab w/sport yesterday evening. Started the mirror install this morning. Tried tapping the mirror mount up, as earlier post suggested, but it didn't seem to want to move. I began applying pressure down on the mirror - not a lot, but steady, even pressure and the mirror released. The Prius mirror slid right on, then I ran the wires(including the radar detector wires) under the headliner as in the Toyota instructions adding the EC mirror(normal Toyota accessory without the Homelink), except I did not remove the overhead console, then down behind the A-pillar trim to the fuse box. The Homelink requires constant 12V power and the EC part of the mirror needs switched 12V. Works like a charm. Now I have temp & compass in the overhead console, an EC mirror and Homelink.
Old 01-27-2005, 07:00 PM
TEFye's Avatar
2005 Toyota Tacoma
Default EC mirror with Homelink pic
Just an update, it's an easy install if you're comfortable removing some of the interior trim(A-pillar, lower instrument panel, driver's kickpanel). Just follow the steps in the knowlegebase for the mirror accessory install. Here's what it all looks like. The part number for this mirror is 00016-47010 and it listed as "PRIUS EC MIR W/HOMLK".
