Can you remember or easily see which wire colors that you tapped into for your setup?
I had a slightly different configuration in mind. Let me run this by you and get your feedback. I don't know if it's a good idea, but I was thinking that this would be a way to run everything. My
primary demand is having
all windows roll up (including sunroof) upon arming of the alarm system. Rolling down with remote is a nice luxury that I don't really need, but if I can do it without a WHOLE LOT more effort, I surely shall.
Here's what I had in mind for the TWO 530Ts that I ordered for this project:
530T module 1 (strictly for rolling UP windows/sunroof upon alarm arming):
** would probably NOT connect the AUX input wire
wire 1: ground to "lock" wire in driver's door to roll up BOTH front windows and sunroof
wire 2: ground to tailgate window "lock" wire to roll it up
wire 3:
ground? to roll up wire on motor in Driver REAR door to roll up that window
wire 4:
ground? to roll up wire on motor in Passenger REAR door to foll up that window
530T module 2 (strictly for rolling DOWN windows/sunroof via remote):
** would probably NOT connect the GROUND WHEN ARMED wire
wire 1: ground to "unlock" wire in driver's door to roll down BOTH front windows and sunroof (while button is pressed).
wire 2: ground to tailgate window "unlock" wire to roll it down
wire 3:
ground? to roll down wire on motor in Drivers REAR door to roll it down
wire 4:
ground? to roll down wire on motor in Passenger REAR door to roll it down
+ note: I do understand that the module is made to roll TWO windows in TWO directions, but was told that the module can be wired to roll FOUR windows in ONE direction (hooking the two roll UP wires on the roll DOWN module to the "opposite wire").
Obviously, I'm utilizing the factory feature that allows you to turn the key in the driver's door to LOCK and roll UP the two front windows AND sunroof and also using the lock wire in the tailgate that also rolls up the rear tailgate window. (I'm
very curious to know if I can just hook in at the switch on the dash instead of running a wire all the way back to the tailgate).
I'd also LOVE to get a
wiring diagram of the power window wires. I've hesitated to pay for subscription to TS.com because I'm not SURE that the information is included with the wiring diagrams. If anyone can confirm this, please let me know. It would certainly be worth the $25 annual.
Any advice is also appreciated. I plan to install this thing the first chance that I have a full day or two with nice weather (no garage). My email is:
bretbowman@yahoo.com
Thanks in advance for anyone's help that can be offered!
Bret
